Prop shaft shims - SailNet Community
post #1 of 4 Old 06-29-2012 Thread Starter
Prop shaft shims
I am placing a small Farymann diesel into a Morgan 28 that formerly had an Atomic four. The farymann came with a coupling with a 1" shaft keyed bore. My prop shaft is 7/8. The prop itself is on a taper at the shaft end with a 1/16" plastic shim. Would it be acceptable practice to use a 1/16 shim on the shaft on the coupling end of the prop shaft to make up the difference?
Thanks for the assistance
gravitta is offline
post #2 of 4 Old 06-29-2012
Re: Prop shaft shims
No this wont be acceptable. I suggest taking the shaft and the coupling to a machine shop and getting them to make and fit a proper adaptor. Using a nylon or plastic shim on the shaft coupling will accentuate any vibration until it all flies apart.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #3 of 4 Old 06-29-2012 Thread Starter
Thanks, I was a bit surprised on the prop end, but guess I was hoping for an easy solution that didn't really seem like it would work on the end requiring some alignment, but your feedback is rational and accepted .
gravitta is offline
post #4 of 4 Old 06-29-2012
Tartan 27' owner
CalebD's Avatar
You might be amazed at what a good prop shop can do. They should be able to re-size the bore of your 7/8" shaft of the prop to accept a 1" shaft. Not sure but it might cost around $150+.
Everybody has one:
CalebD is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 06:50 PM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
prop shaft redhead78 Gear & Maintenance 14 05-03-2010 06:45 PM
prop shaft jdair101 Gear & Maintenance 3 11-09-2008 06:13 AM
Prop/Prop-Shaft Key Size? Skipaway Gear & Maintenance 7 07-29-2008 09:04 PM
