Volvo Penta 2003 - SailNet Community
post #1 of 8 Old 07-08-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Volvo Penta 2003
I changed out the Racor Filter on the engine and when I tried to bleed the fuel lines using the lever on the fuel pump I never got any fuel to come out of the vent bolt on the secondry filter. Finally I gave up and tried starting the engine-successfully. Which one is the correct blled bolt? The one with the fuel lines attached of the one in front of it?
brokesailor is offline
post #2 of 8 Old 07-08-2012
jimrafford's Avatar
Re: Volvo Penta 2003
I don't remember of the top of my head. I'll bring home my manual tomorrow and look it up.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #3 of 8 Old 07-08-2012
rccu's Avatar
Volvo Penta 2003
I have the same (or similar) engine, Volvo Penta 2003t, on my boat. The bleed bolt is the one one on the top of the secondary filter that's closer to the front. Be careful not to over-tighten it, they break easily.
Not sure how your engine is equipped, but the oil cooler on mine just failed due to salt water corrosion. If you know of a source of used spare parts, please pass on the contact info. Volvo wants $1,800 for a new one. I just rebuilt my engine and have many other spares , if you're interested.
1991 Beneteau First 38s5 "Biondina"
Savannah, GA
rccu is offline
post #4 of 8 Old 07-09-2012
rccu's Avatar
Sorry, but I do not have enough posts to send you a PM. My e-mail is rccu1999 at msn dot com. Many thanks.
rccu is offline
post #5 of 8 Old 07-10-2012
If you fill the new filter w/ fuel (or injector fluid as was once recommended) you should be able to screw the filter assembly on and start w/o having to bleed. Least I was!
CS 36M DIANTHUS
sailordave is offline
post #6 of 8 Old 09-28-2012
Seeker
zaliasvejas's Avatar
Keep pumping...
Fill the secondary filter with fuel before you install it and pump... It takes a while. The vent bolt is the highest above filter..
zaliasvejas is offline
post #7 of 8 Old 09-28-2012
Volvos are a monumental rip-off with spare parts.
Avoid. Avoid. Avoid.
Buy a Kubota, or something.
Rockter is offline
post #8 of 8 Old 09-29-2012
Turn the engine over a using the starter or by hand once or twice. The pump could have been sitting at the bottom of the its stroke and will not pump using the leaver.
SOLARWIND is offline
Volvo Penta 2003 Trans oil? DoubleEnder Diesel 5 06-11-2012 05:40 AM
Volvo 2003 gearbox j34035 Diesel 1 01-24-2010 05:15 AM
Winterizing Volvo 2003 moonie5961 Diesel 2 12-04-2009 08:10 AM
Volvo Penta 2003 to 2003T fawcettm Gear & Maintenance 0 05-05-2009 09:44 AM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 05:54 PM
