Universal 5416 exhaust riser - SailNet Community
post #1 of 10 Old 07-09-2012 Thread Starter
I need to change the part on the picture (I believe it is called exhaust riser or something like that):
As you could see it has a hole in the exhaust and it developed when I was transferring my boat between the moorings, so I "fixed" it with duct tape (which was breached as you could see).
What's the best place to buy the replacement part and is it going to be hard to replace myself or I am better of hiring someone to do it? It doesn't look too complicated, there are a couple of bolts that are a bit rusted, but I think should come off without too much trouble. Any caveats/things to look for?
Romario is offline
post #2 of 10 Old 07-09-2012
One of None
deniseO30's Avatar
Re: Universal 5416 exhaust riser
Looks like mine! less the soot.. bummer I believe it's made from standard 1-1/4" iron pipe nipples and fittings. There is one difference, on my boat, is in the elbow rather then below the 90 degree elbow like yours, don't think it matters.
My last project!
deniseO30 is offline
post #3 of 10 Old 07-09-2012 Thread Starter
Called the store, they say it is just a piping system and that any black pipe from hardware store can be used.
They gave me this part:
90 DEGREE WATER INJECTED ELBOW MMD MMD33067 Sailboat Supplies, Engine Parts and Boat Parts
but said it's 1-1/2'' and the exit on the engine is 1-1/4'', so I would need to somehow make a connection.
There is also this part:
Sailboat Supplies, Engine Parts and Boat Parts but i am not sure it will fit.
Romario is offline
post #4 of 10 Old 07-09-2012
JimsCAL's Avatar
I made up the exhaust riser for the Universal 5411 on my previous boat out of 1 1/4" NPT black iron fitting and nipples from Home Depot. Assume the 5416 is the same size. Made the water injection fitting out of a tee, reducer and nipple to attach the water hose. Total cost of everything was about $30. The second part you show looks like it would work assuming it's 1 1/4" NPT. Looks a lot like what's on your boat.
JimsCAL is offline
post #5 of 10 Old 07-09-2012 Thread Starter
That makes sense. I could use something like
and a reducer to put the water pipe there.
Was it hard to unscrew the old parts?
Romario is offline
post #6 of 10 Old 07-10-2012
JimsCAL's Avatar
A tee like that would be ideal. I used a standard tee which was how the boat came from the factory. And getting the old system apart is going to be the tough part of the job. A recprocating saw with a metal cutting blade can cut most of it out. You must unscrew the nipple going into the engine exhaust flange however. Spray with PB Blaster for several days prior to trying.
JimsCAL is offline
post #7 of 10 Old 07-10-2012 Thread Starter
Do you remember the size of the rubber hose that feeds the seawater? Or maybe someone can measure, my boat is several hours away, so I can only measure on the weekends.
Romario is offline
post #8 of 10 Old 07-10-2012 Thread Starter
also - what wall thickness should I use for the pipes?
Romario is offline
post #9 of 10 Old 07-10-2012
Use sch 40 pipe. Looks easy to cut and weld one up. Practical Boat Owner said any riser should rise at least 16 inches before any water gets injected. I prefer dry exhuasts . As one diesel mechanic said "If everyone went for dry exhaust and keel cooling, us mechanics would all be out of work."
Brent Swain is offline
post #10 of 10 Old 07-11-2012
JimsCAL's Avatar
Hose is probably either 1/2 inch or 5/8 inch ID. You'll have to check to see which. You will have trouble finding other than Schedule 40 nipples and fittings.
JimsCAL is offline
My Universal 5416 is which kubota engine?? deniseO30 Diesel 19 08-10-2014 01:57 PM
universal 5416 problem and solution bmorena Diesel 5 03-24-2012 08:33 PM
Yanmar SB8 exhaust riser wally27 General Discussion (sailing related) 0 10-31-2011 03:55 PM
Universal 5416 filters deniseO30 Gear & Maintenance 3 05-05-2009 10:50 AM
zinc in Universal 5416? wumhenry Gear & Maintenance 12 05-16-2007 04:01 PM
