4-107 Fuel Return Lines - SailNet Community
post #1 of 4 Old 07-20-2012 Thread Starter
The ones between the injectors. One was leaking, I changed them all. The old stuff was stiff plastic, press fit. The new stuff is rubbery, also press fit. It keeps popping off. I haven't found clamps that small. I tried zip ties, not good enough. I tried gasket sealer, not good enough. It seems to build pressure then pop off with a spray of diesel. I checked the other end, it's full of fuel. So it's not blocked. Anyone else had this problem?
WanderingStar is offline
post #2 of 4 Old 09-09-2012
Maine Member
BELLATRIX1965's Avatar
Re: 4-107 Fuel Return Lines
Sorry for not replying to your post sooner (I haven't been on SailNet much this summer). The "right stuff" for these injector return lines is .190" by .250" by .030" Nylon -12 semi-rigid black tubing. I renewed mine a year or two ago, and have the remains of a 10 foot coil still in the bag down cellar. If you want to PM me your mailing address, I'll send you a piece long enough to re-do yours (no charge - just pay a favor forward for someone else).
This material is push-on, and theoretically does not require any "hose clamps". Mine is fine between the injectors, but does leak a little at the one connection on top of the fuel filter assembly. I couldn't find hose clamps small enough either, and tried using SS tie wire - slowed the leak but didn't stop it.
If you find any miniature hose clamps, please let us all know!
If the new tubing "blows off" - you may have blockage somewhere in your fuel return system. There is a small ball check valve inside the banjo bolt assembly at the top of the fuel filter - maybe plugged?
BELLATRIX1965 is offline
post #3 of 4 Old 09-12-2012
Try a motorcycle shop for small hose clamps.
INMA is offline
post #4 of 4 Old 09-14-2012 Thread Starter
Thank you both. I haven't been on SN much lately either. I'm about to try some reinforced hose with small screw clamps. I did try removing one section at a time to see if the flow was restricted, it seems not. Bella, I will PM you, thanks.
rerouting fuel return away from tank HUGOSALT Diesel 9 03-20-2012 07:12 PM
Fuel line return jimhuggins0350 Pacific Seacraft 6 07-18-2011 10:39 PM
fuel-return line.. . whatoo General Discussion (sailing related) 5 03-31-2006 08:19 AM
Fuel Return Ratio pma_foyl Gear & Maintenance 8 07-22-2004 01:22 AM
Fuel Return Ratio pma_foyl General Discussion (sailing related) 1 07-09-2004 10:10 AM
