Tips for generator diagnosis? - SailNet Community
post #1 of 5 Old 07-22-2012 Thread Starter
lajimo's Avatar
I have a Mase 4001 with 421 hrs / 5 years old. Starter was replaced 5 months ago. It was running fine until this past weekend when 2 minutes after startup it quit with an E-82 message - temperature too high. Checked input water flow before and after the strainer - ok. Checked oil - ok. Tried it again, same result. Let it "rest" overnight and now it won't give any response to starter at all - seems like an internal fuse went out? Any ideas/recommendations ? Thanks
lajimo is offline
post #2 of 5 Old 07-22-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Tips for generator diagnosis?
Sounds like a sending unit to me. Have u tried bypassing them? Generally this is done by shorting out the connection. For the smarter generators, which run through computers, if they do not see voltage through the temp or oil pressure su within a certain period of time, they shut down. The temp unit maybe turned on with voltage, incidentally, cant remember. If the temp su has failed, it wont bother starting. That is my first guess.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #3 of 5 Old 07-22-2012 Thread Starter
lajimo's Avatar
Good idea -thanks
lajimo is offline
post #4 of 5 Old 07-22-2012
I have an 8k Mase and, once in a while, I need to kill all power to it to let the brains reset or it thinks one of the sensors is showing a fault. Oil and/or temp. Quick reset and she's good to go. Happens about once per year.
Jeanneau 54DS
Minnewaska is offline
post #5 of 5 Old 07-22-2012 Thread Starter
lajimo's Avatar
That's interesting - i will give that a try.
lajimo is offline
Best generator prroots Electrical Systems 12 01-17-2012 11:52 AM
Another Exhaust Smoke Diagnosis DrB Diesel 1 07-06-2010 09:46 AM
Tranny smoking, then slipping - diagnosis process? Pub911 Gear & Maintenance 7 12-02-2008 10:05 PM
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 01:01 AM
