Diesel Engine trouble-shooting - Page 2 - SailNet Community
post #11 of 12 Old 08-14-2012
Seņor Member
PorFin's Avatar
Re: Diesel Engine trouble-shooting
Jordan,
You may want to check and see if your fuel pick-up tube has a screen filter attached at the bottom -- some do, and they invariably cause problems. If there's a screen there, I'd take it off.
PorFin is offline
post #12 of 12 Old 08-14-2012
Senior Smart Aleck
jameswilson29's Avatar
I used a fuel polishing and tank cleaning service this past Spring. The fuel is run through filters and then discharged under pressure back into the tank where it dislodges the accumulated solids in the tank, which are then withdrawn out of the tank and into the filters. This was done continuously for nearly three hours.
It should result in clean fuel and a clean tank (and a lighter wallet).
jameswilson29 is offline
Trouble shooting wind instrument. L124C Gear & Maintenance 27 2 Weeks Ago 11:29 PM
trouble shooting DataMarine S-200DL Depth Sounder alman Electronics 2 11-15-2010 12:51 AM
Auto Pilot Trouble-Shooting Needed Pub911 Gear & Maintenance 1 04-05-2010 06:58 AM
Trouble Shooting Moors Depth Sounder Finallybuyingaboat Gear & Maintenance 1 10-23-2007 11:07 PM
Trouble-shooting depth and speed guages billkidd Gear & Maintenance 0 08-20-2002 08:49 AM
