Diesel Engine trouble-shooting - SailNet Community
post #1 of 12 Old 08-11-2012 Thread Starter
JordanH's Avatar
Hi guys,
I'm looking for some generic diesel engine trouble shooting. If you have experience with the Farymann K34, then all the better.
The back story is that my trusty engine stalled on my while exiting Port Dalhousie last weekend. I haven't had a chance to look at anything (almost anything) yet and want to use my time wisely trouble shooting.
Symptoms
- Leaving port, the engine struggled for a second or two, I looked down as the oil pressure suddenly dropped from its cold 60psi to 0psi. Both warning lights came on and the engine stalled.
- Later, i started the engine and ran it for 30 minutes. It sounded like it was labouring slightly (maybe only I would notice it) and came close to stalling.
- Upon arriving in Etobicoke, the I started the engine for less than 5 minutes to get me into the slip. Our green warning light came on and flickered... this is new, never seen it on before.
- My temperature gauge has not moved... either broken or the engine is not warm yet; Both are quite possible.
Trouble shooting steps
- Pull the fuel filter and check for grunge. Check the fuel for bacteria growth. (I have not done this yet)
- Look for water coming out of the exhaust.
- Check the cooling impeller to make sure it is free, clear and all fins are intact. (I did this yesterday. All looks well.)
- Check oil level. (I did this yesterday and it is at the full line with no outward signs of leaks on the engine.)
I'm not sure what the green warning light is. It's either charging light or temperature but I've never had cause to see where it might be connected.
What other steps should I take before I seek the advice from a professional?
Regards,
Jordan.
(Please excuse the cross-post from CO26.com)
JordanH is offline
post #2 of 12 Old 08-11-2012
davidpm's Avatar
Re: Diesel Engine trouble-shooting
Sucking air is a pretty common cause of a diesel stalling.
Have you done anything recently to the engine?
Maybe you checked the fuel filter and did not tighten it quite right.
davidpm is online now
post #3 of 12 Old 08-12-2012
Sailor
Gladrags1's Avatar
I second the thought about air getting in the lines or perhaps a clogged filter. If you've checked the impeller and found it to be ok, it probably is not overheating. Besides, I had the impression from your description that the engine had not run a long time before dying. So, I think fuel delivery problem; air in lines or dirty, clogged filter.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 12 Old 08-12-2012
kd3pc's Avatar
I would check the fuel pickup tube as well, as she quit while in motion....
the lights are a result of the engine stalling, not the other way around....
the engine needs air, steady clean fuel, and enough revolutions to compress the fuel to fire...
even after 40 years, I always check upon startup to see that the engine is shipping water...and often while running...
kd3pc is offline
post #5 of 12 Old 08-12-2012 Thread Starter
JordanH's Avatar
Thanks davidpm. Yes, air getting in definitely crossed my mind (I had this problem last year) but I forgot to jot it down. Any advice for how to determine where air is getting in?
Last year, it was the crush washers around the... lift pump... (I think I have that term correct).
While I was going through the chop exiting the channel, heeled to starboard (tank on starboard) I thought it might have sloshed the 1/2 tank of fuel enough such that it got a mouthful of air. But later on, it also slogged down a bit which is strange as the lake was dead calm and we were upright.
kd3pc, I know what you are thinking here, but I'm not quite that clueless. ;-) Yes, the lights pop on when the engine stalls and that may have been the case on the first stall. However, when we arrived at home, the engine was running with the green light flickering. Not both lights, not solid and the engine was running for several minutes while this was occurring. The latter case was definitely not a result of a stall.
Hopefully I can find time today to get to the boat and figure out where that green light is attached.
JordanH is offline
post #6 of 12 Old 08-13-2012 Thread Starter
JordanH's Avatar
More info...
I'm on the boat as I type this...
After using the battery for radio and wind instruments on a 10hr trip without recharging, and sitting for a week, the battery still reads 12.15V.
I start the engine and leave it at idle. The battery now reads 12.4V.
I rev the engine under load (tied to dock, half-throttle). The battery now reads 12.4V. I expected more...
I rev the engine under load (tied to dock, full-throttle). The battery now reads 13.9V. This is what I expected.
The engine still seems to be labouring.
I have verified the impeller still looks pristine (only about 6hours on it).
I have verified that I am evacuating water from the exhaust.
I have verified that the oil is topped up and doesn't appear to have dropped at all since the oil change (about 6 engine hours ago).
I will be checking the fuel & fuel filter shortly.
The green light is still flicking on my panel... I'm pretty sure that's the charge light, not temperature. I've been given some advice on how to check the stator but I'm still lost. Any further advice would be welcome.
JordanH is offline
post #7 of 12 Old 08-13-2012 Thread Starter
JordanH's Avatar
It appears that there was a half-teaspoon of water in the fuel filter cup, which I emptied. At first, I thought this may have gotten shaken up and pushed into the engine. However, when I reattached the fuel filter I had no success bleeding the fuel line. I detached the fuel filter intake and tried to start the syphon. Sucking on the hose was unusually difficult and the syphon, once started, wouldn't continue. I suspected a clogged intake so I blew as hard as I could through the line a few times and that seemed to loosen everything up.
The syphon runs cleanly now and the engine has been running for 20 minutes and sounds good.
So the problem is likely a clogged intake, but since I only temporarily unclogged it... uhm... how the heck am I going to clean the tank?! The closest thing to an inspection hatch is the fuel filler hose attachment which is barely big enough to see in, let alone reach in to clean.
What methods are there for cleaning out an old diesel tank? I don't think I should take my buddy's suggestion of a hose and dish detergent... ;-)
Maybe I'll call a mechanic to price a new plastic tank.
JordanH is offline
post #8 of 12 Old 08-13-2012
davidpm's Avatar
maybe you have two things going on. Wouldn't be the first time.
A charge problem and a fuel problem.
post #9 of 12 Old 08-13-2012
davidpm's Avatar
There are fuel polishing services. they pump your fuel through a series of filters to make sure it is clean.
post #10 of 12 Old 08-13-2012 Thread Starter
JordanH's Avatar
I imagine that will cost more than the 10 or 20L of fuel actually in the tank. But the problem is what's in the tank... I imagine, and I have to use my imagination since I can't see in there, it has some rust and debris that needs to be washed, cleaned out and then repaired or it will continue to rust.
JordanH is offline
Trouble shooting wind instrument. L124C Gear & Maintenance 15 07-30-2015 09:11 AM
trouble shooting DataMarine S-200DL Depth Sounder alman Electronics 2 11-15-2010 12:51 AM
Auto Pilot Trouble-Shooting Needed Pub911 Gear & Maintenance 1 04-05-2010 06:58 AM
Trouble Shooting Moors Depth Sounder Finallybuyingaboat Gear & Maintenance 1 10-23-2007 11:07 PM
Trouble-shooting depth and speed guages billkidd Gear & Maintenance 0 08-20-2002 08:49 AM
