Compression fittings at injector leaking - SailNet Community
 2Likes
  • 1 Post By BELLATRIX1965
  • 1 Post By jrd22
post #1 of 7 Old 08-12-2012 Thread Starter
I just replaced the copper washers at the bottom of my injectors, and now I have a leak at one of the fittings where the fuel pipe connects to the injector with a compression fitting. Is it common to use some sort of sealant (teflon paste or tape) on the fittings? I'd hate to get some teflon tape in the injector!
Advice from experience?
Thanks
PK
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
preservedkillick is offline
post #2 of 7 Old 08-12-2012
Senior Cruiser
sea_hunter's Avatar
Did you put them in the right way? One side is down the other up, but once crushed they need to be replaced perhaps they haven't seated, loosen the nuts then retighten them. Don't over tighten, if your unsure check your manual for the proper torque.
sea_hunter is offline
post #3 of 7 Old 08-12-2012
Courtney the Dancer
jrd22's Avatar
Re: Compression fittings at injector leaking
Are you talking about the crush washers on the return line? Usually the high pressure supply line is a flare fitting on the top of the injector. If the crush washers on the return are leaking get two new washers and torque to factory specs.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #4 of 7 Old 08-13-2012 Thread Starter
I should have been more accurate, yes I'm talking about the high pressure supply line. Where 11 meets 6.
https://picasaweb.google.com/lh/phot...eat=directlink
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
post #5 of 7 Old 09-09-2012
Maine Member
BELLATRIX1965's Avatar
High pressure fuel lines should be made up clean and dry - NEVER put anything in that area (even anti-sieze) that could be carried into the fuel injector and plug up the fuel passages / injector tip orifices. I would try: inspect the seating surfaces, carefully spraying the fuel line end and injector HP connection fitting with quick-dry degreaser, wipe clean with a lint-free rag, and re-torque to manufacturer's specs. If it still leaks, you may need to renew the HP fuel line and/or the injector inlet connector. High pressure diesel fuel is not very forgiving! Good luck, and let us know how you made out!
jrd22 likes this.
BELLATRIX1965 is offline
post #6 of 7 Old 09-09-2012
Courtney the Dancer
jrd22's Avatar
Sorry I didn't get back to you Preserved. I agree with what Bella said, no sealant. Most likely there is damage to one surface or the other or there is a crack in the line at the fitting.
Faster likes this.
John
SV Laurie Anne
jrd22 is offline
post #7 of 7 Old 10-27-2012
Remove the line in question. It has a built in seat that fits into female counterpart on injector. Check line for imprint of previous "fit". One tiny grain of sand can interupt this. fuel can be up to 3000PSI here. an improper fit/ angle can upset previous fit. You may have to loosen injector a touch to rotate a touch... very small amount.You shouldnt have to coax line into where its going. If it has been bent, it may not reseat correctly into socket on injector.
Paladin is offline
Help! Leaking Injector Pump Classic30 Diesel 87 03-31-2014 12:29 PM
Fuel Injector Pump leaking Axle2121 Gear & Maintenance 18 10-02-2012 03:55 PM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
Bleeding air at injector jslade8581 Diesel 26 02-26-2012 09:55 AM
Injector leaking CaptGum Diesel 0 02-24-2012 12:33 PM
