Installing engine gauges - Page 2 - SailNet Community
 4Likes
post #11 of 18 Old 08-20-2012
Re: Installing engine gauges
Also Cruzpro guages. They have adjustments for various senders and alarm temperature. I have one of their temp guages for my 2GMF. Works fine. A little difficult to see the reading but I have it in a oddball place. It has a backlight.
Chuck Bauer
chuckbauer is offline
post #12 of 18 Old 08-22-2012 Thread Starter
L124C's Avatar
Originally Posted by remetau View Post
Look into Murphy gauges. They allow you to have an alarm and light without having to use a T fitting. They are also adjustable to where you want the alarm to go off at.
Wow! Thanks for that. The Murphy documentation is very informative and much better than other gauge mfg's I have been looking at. Looks like these gauges and senders are exactly what I need.
My only questions now are:
Can I use the existing Yanmar alarm with the Murphy sender and gauge?
What size are the Yanmar sender threads? I'm guessing 1/2" npt.
I'll call the sales rep. for the first question and hopefully, they will know the second. If anyone here knows, please advise.
Thanks again!
L124C is offline
post #13 of 18 Old 08-22-2012
remetau's Avatar
Thanks again!
NP. I have been very happy with my gauges. Call them, I found them to be very friendly and helpful. I can't remember the thread sizes, but they offer them in difference sizes. I used my existing Yanmar buzzer and dummy lights.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #14 of 18 Old 08-30-2012 Thread Starter
L124C's Avatar
Originally Posted by chuckbauer View Post
Also Cruzpro gauges. They have adjustments for various senders and alarm temperature. I have one of their temp gauges for my 2GMF. Works fine. A little difficult to see the reading but I have it in a oddball place. It has a backlight.
Chuck Bauer
Hmmmm. I was wondering why all the gauges I was seeing were analog. The Cuzpro digitals look good. I wonder why all gauges are not digital now? They appear to be about three times more expensive, but it seems they would be more accurate and easier to read. Drawbacks?http://www.cruzpro.co.nz/index.html
L124C is offline
post #15 of 18 Old 08-30-2012
My guess is that analog is simpler, no "brain" to convert the variable resistance signal into digital numbers? Analog readings should be fairly accurate.
Paul T
dabnis is offline
post #16 of 18 Old 09-02-2012
No drawbacks noticed for the Cruzpro temperature gauge. Took a while to find a sender with the proper threads. (I wouldn't settle for the close enough approach in thread type)
After having to replace the recirculating cooling water pump I discovered an extra sensor port so I was able to reinstall the original idiot light temp switch and now have both in cockpit and in cabin alarms. Haven't had either go off yet.
Chuck Bauer
post #17 of 18 Old 03-12-2013
I know this is an old thread but....
I would avoid an ammeter like the plague, I had two '60s vintage cars charging systems totally cut out with no obvious reason due to gauges with the entire alternator output running through them going kuput. Took me forever to diagnose the problem the first time.
Just my .02$
oldfurr is offline
post #18 of 18 Old 03-13-2013 Thread Starter
L124C's Avatar
Just my .02$
Thanks for the input.
I don't think the age of any thread matters unless the technology is obsolete (Often with PC's, not likely with sailboats) or the subject matter is of a timely nature (i.e., current weather/tidal conditions). A pet peeve of mine is when members post before they search. Why re-invent the wheel when so much information has already been discussed? When possible, add...don't duplicate...IMHO
L124C is offline
ST50 Gauges ltgoshen Gear & Maintenance 5 05-13-2012 09:31 PM
Changing Out Engine Gauges/Tach Problem H2814D Diesel 3 03-13-2012 08:09 AM
Teleflex Gauges clarity36 Electrical Systems 1 11-07-2010 10:30 AM
Older EMS gauges ckgreenman Gear & Maintenance 8 10-06-2009 11:09 PM
Fuel Gauges teshannon Gear & Maintenance 17 07-18-2007 02:42 PM
