Installing engine gauges - SailNet Community
 4Likes
post #1 of 18 Old 08-14-2012 Thread Starter
L124C's Avatar
I have a old Yanmar GM20 that still runs great. It has idiot lights and alarms, but I always feel like I should have gauges, hopefully to give me a little advance warning of a system failure, and for redundancy. I'm thinking about an ameter, voltmeter, water temp and oil pressure gauge.
How difficult is it to install after market gauges on an old diesel?
Is it worthwhile?
Do I need to buy Yanmar gauges?
If not, any recommendations on gauge manufactures?
L124C is offline
post #2 of 18 Old 08-14-2012
Re: Installing engine gauges
You should be able to replace your sending units for the idiot lights with analog sensors matched to gauges, as long as the connecting threads match. Any good quality gauge set should do I'd think. You may have to fabricate your own panel for a good fit, most non marine gauge sets use 'under dash' mounts that may not stand up in a marine environment...
Faster is online now
post #3 of 18 Old 08-14-2012
remetau's Avatar
I have a 3QM30F and put in an OEM brand tach instead, but it may depend on the type of sending unit you have. I used Murphy gauges for the oil pressure and temp since they allow for a separate alarm off of the gauge.
L124C likes this.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #4 of 18 Old 08-14-2012
You might consider using a "T" fitting, if it will fit, allowing you to keep the lights and have the gauges. I have used brass fittings for years without any problem but have read they are subject to vibration fatigue. Steel fitings, although subject to surface rust, may be a better choice?
Paul T
dabnis is offline
post #5 of 18 Old 08-19-2012
Stu Jackson's Avatar
You don't want an ammeter unless you get one with a remote shunt. Older engines with ammeters in their cockpits had the alternator output (i.e., charging wire) go all the way to the cockpit and then back to the batteries in very small wire. Buy a battery monitor and put a voltmeter in your cockpit.
rikhall and oldfurr like this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #6 of 18 Old 08-19-2012 Thread Starter
L124C's Avatar
Paul T
I'm having trouble understanding how I install the fitting. Here are pictures of my oil pressure (yellow wire) and water temp sending units. Can somebody explain the process for me?
Thanks!
L124C is offline
post #7 of 18 Old 08-19-2012
Looks like things are pretty tight for a "T" fitting? You might be able to install a short piece of pipe as an extender to get room for the "T" fitting. However that might be subject to vibration fatigue and break off, very bad. Looks like the simplest and safest way to go would be to just replace the light sending units with gauge senders.
Paul T
dabnis is offline
post #8 of 18 Old 08-20-2012 Thread Starter
L124C's Avatar
Paul T
Thanks. I think I have space for a "T" unless its bigger than I can imagine. I'm tolally ignorant about how these senders work. Whats in the "pipe"? Current? Pressure? I'm trying to figure out how a light/buzzer and gauge operate off the same sender.
How do you attach an extension (solder/brazing)?
I assume if I replace the sending units with gauge units, I lose the lights and buzzers (something I would prefer not to do, as they both have their advantages and disadvantages IMO).
L124C is offline
post #9 of 18 Old 08-20-2012
remetau's Avatar
Look into Murphy gauges. They allow you to have an alarm and light without having to use a T fitting. They are also adjustable to where you want the alarm to go off at.
L124C likes this.
Don & Diana
remetau is offline
post #10 of 18 Old 08-20-2012
Very good features, didn't know they existed. Better than "T" fittings and seperate senders:
Palmer Johnson Power Systems - EG Series Electric Gauges
Paul T
dabnis is offline
ST50 Gauges ltgoshen Gear & Maintenance 5 05-13-2012 10:31 PM
Changing Out Engine Gauges/Tach Problem H2814D Diesel 3 03-13-2012 09:09 AM
Teleflex Gauges clarity36 Electrical Systems 1 11-07-2010 11:30 AM
Older EMS gauges ckgreenman Gear & Maintenance 8 10-07-2009 12:09 AM
Fuel Gauges teshannon Gear & Maintenance 17 07-18-2007 03:42 PM
