Yanmar 2GM Winterization System Failure - SailNet Community
post #1 of 4 Old 09-04-2012 Thread Starter
I was out putting around last weekend for a few hours. I heard a bang while I was in the head, but did not think much of it, since there were plenty of others aboard that could make such a sound. We were really moving slow like 1000 rpm.
When entering the harbor the engine was pushed to about 2000rmps. The engine seemed a little down on power. After a minute or two I noticed a hollow sound coming from the muffler canister, and then a farting rather than splashing from the stern. I looked down and of course there was no water coming out. We were in a busy channel so we reduced rpms and got out of the way (maybe another minute or two).
I went below to take a look at the engine and water was spraying out of the water hose that connects the thermostat to the mixing elbow. The previous owner had rigged up a winterization system with a lot of extra fittings and hose. I didnít even use it for the single winterization I have done, and it was on my to do list to remove all of it. On this particular hose there was a brazed copper elbow, which cracked right at the corner. I shut down the engine, dried the fitting, liberally applied duct tape, and moved slowly the next 5 minutes to my slip. When I returned to the slip I placed my hand around the engine and did not feel any hot spots
I have spent the last year doing a lot of projects on the boat, but this is the first failure that could have been particularly damaging, or even dangerous.
I have a few questions:
Is it likely that I caused any damage to my engine? What items require close inspection? Can I use any marine water hose, or is it best to replace with the molded (I would guess) yanmar part?
Al Woods
Al Woods
aloneinthewoods is offline
post #2 of 4 Old 09-04-2012
jsaronson's Avatar
Assuming your temp alarm works and you did not run the engine hard after it went off for very long u r fine. I'd think any hose would do.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #3 of 4 Old 09-06-2012 Thread Starter
Re: Yanmar 2GM Winterization System Failure
Thanks for the reassurance.
post #4 of 4 Old 09-06-2012
The exhaust will have gotten very hot, but the motor will not have been starved of coolant as the water pump was still circulating as normal.
Your engine room will have still gotten its share of salt water spray.
Just check the exhaust for having been cooked.
Avoid copper in the presence of salt water.
Try to use bronze and cast iron.
Rockter is offline
Tags
yanmar 2gm
Yanmar 3GM oil line failure jrd22 Diesel 32 01-18-2016 12:29 PM
Yanmar YM oil pressure alarm failure ctlow Diesel 9 06-27-2013 06:07 PM
Diagnosing Yanmar warning horn failure mbsl98 Diesel 9 08-06-2012 10:13 AM
Yanmar 3ym20 pre mature water pump failure jbrockpiano Diesel 7 09-19-2010 10:25 AM
Salt Water Cooling System failure. rclampitt Gear & Maintenance 4 07-28-2002 10:26 PM
