Volvo penta 2002 - SailNet Community
post #1 of 4 Old 09-05-2012 Thread Starter
Volvo penta 2002
Help I have a Volvo penta 2002 I started the boat yesterday and left it running when I was working the engine was running fine then it lost revs and stalled it will start again if you pull out the stop and resetting the cold start but it will not run at low speed and also very sluggish it is also leaving black soot on the water surface from the exhaust sea water cooled i changed all filters and cleaned fuel pump and diaphram I cut open the rack filter and all seamed clean I have checked fuel lines for leaks and when fuel pump is primed fuel is spurting from the bleed screw any ideas??
Wallace39 is offline
post #2 of 4 Old 09-07-2012
Re: Volvo penta 2002
iwishiknewwhatthehellyouaretalkingaboutthenexttime youwanthelpdothereaderthecourtesyofpunctuatingyour textsotheygettheideathatitisimportantenoughtoyouto typepropersentences
Rockter is offline
post #3 of 4 Old 09-07-2012
Send a message via AIM to HPLou
The problem sounds like it is in the fuel injection system. The first thing I would suggest looking at would be the fuel injectors.
HPLou is offline
post #4 of 4 Old 10-20-2012
Check for exhaust backup...possibly exhaust elbow
Alive3and3Well is offline
Volvo Penta 2002 - Stalling and rough idle - HELP! HBBurlington CS Yachts 12 05-18-2015 10:42 AM
Volvo Penta 2002 18 hp. after 5 to 30 minutes jtownsail Diesel 5 02-09-2015 06:44 AM
Volvo Penta 2002, MS 2B, yr 1991 zinc Westerly Pippin Diesel 8 03-11-2013 12:35 PM
Volvo Penta 2002 engine gauge davidpm Gear & Maintenance 6 05-02-2012 07:22 PM
Volvo Penta 2002 18 hp - turn key, Nothing! dwayne908 Diesel 17 08-30-2009 02:14 AM
