Confused About Reverse/Forward Gear - SailNet Community
 1Likes
  • 1 Post By Capt. Gary Randall
post #1 of 8 Old 09-09-2012 Thread Starter
I have a 79 bayliner bucaneer with inboard deisel md7a penta. My owners manual shows I have a reverse gear box for reverse gear and it uses the same oil as the engine. Is the fluid for the forward gear transmission in that reverse gear box also "is reverse gear housing the same as forward gear or is the oil for the foward geard transmission from the engine itself? My freind has a motor in his sailboat and all the forward gear oil is in same place as engine oil. Is my forward gear oil the same as where the engine oil is like his since the box for reverse gear is called reverse gear and not transmission or forward transmission.
itsme1414 is offline
post #2 of 8 Old 09-09-2012
Capt. Gary Randall's Avatar
Re: Confused About Reverse/Forward Gear
Hello there, the term reverse gear doe's not mean the transmission has a separate housing for reverse. The term reverse gear means the reduction gear ratio is developed so that the engine turns opposite the rotation from the transmission when in forward.so with that in mind if your transmission is turning left hand. Your engine is turning right hand. A typical reverse gear contains both forward and reverse in the same housing.... Captg
jrd22 likes this.
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
post #3 of 8 Old 09-09-2012
Same as a car transmission...one unit handles it all, both forward and reverse.
Catalina 34
chuck53 is offline
post #4 of 8 Old 09-10-2012
The reverse gear simple reverses the drive. The forward and reverse components of the gearbox will share the same lubricant.
Sample some of the gearbox oil. Just remove the dipstick and rub some of it onto your clean hand. If it has the odour of sulphur, it is gear oil and it will have its own self-contained oil bath. If it does not, it is probably engine oil lubricated (the gearbox shares the engine lubricant). If so, typically it gets black much quicker.
The gearbox on your engine has 3 settings - forward, neutral and reverse. It does not have a dedicated gearbox for reverse. It has a dedicated gear for it to reverse the drive, but it is not in a separate gearbox.
Rockter is offline
post #5 of 8 Old 09-10-2012 Thread Starter
Thanks to everyone for clearing that up.
post #6 of 8 Old 09-10-2012
TQA
Bombay Explorer 44
TQA's Avatar
I have never seen or heard of a marine setup where the gearbox shared the engine oil. Even in automobile use this is very rare.
Does anyone know of such a marine setup?
TQA is online now
post #7 of 8 Old 09-12-2012
SchockT's Avatar
Volvo specifies the same oil for the transmission as is used in the engine, but they are separate sumps. I can't imagine why a manufacturer would want to share the same oil between gerbox and engine. Is there such a creature?
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #8 of 8 Old 10-26-2013
The Albin AD2 which was original in my 1969 Columbia 36 used a shared oil supply for engine and gear, just like most Japanese motorcycles. It had a separate reduction gear bolted onto the output shaft which had it's own sump and used the same type oil. It' the only one I've ever seen like.
capt jgwinks is offline
Volvo MSB reverse gear StillWet Diesel 4 11-05-2010 10:35 PM
Sail in Forward, Reverse, or Neutral? elcap373 Gear & Maintenance 15 01-25-2010 07:05 PM
yanmar 2QM2O- REVERSE WORKS- NO FORWARD hertfordnc Gear & Maintenance 17 01-06-2009 02:54 PM
2GM Transmission, going forward when engaging into reverse Stephane99 Gear & Maintenance 2 10-20-2008 10:19 AM
Shaft Vibration in Forward but not reverse bstrebe Gear & Maintenance 6 10-28-2003 07:17 AM
