Fuel tank install - SailNet Community
post #1 of 2 Old 09-11-2012 Thread Starter
Fuel tank install
Due to some sludge in the bottom of my 23 y.o. tank I pulled it this weekend. Off to the shop to get cleaned and the bottom replaced since it was pitted.
Natural consequence of sitting on a surface and moisture being held up against the aluminum for years.
Plan is to glue some thin strips of Acetal (Delrin) on the bottom w/ 4200 so this won't happen over the next 23 years and reinstall.
Since getting the bloody fuel fill hose off was a real pain in the....
I was wondering what I should lube up the inside of the hose w/ prior to installing so it goes on a bit easier? A smear of diesel fuel?
CS 36M DIANTHUS
sailordave is offline
post #2 of 2 Old 09-11-2012
Fuel tank install
I wouldn't use anything. Pulling a hose off is often hard to do because pulling on hose reduces the diameter making it grip more. Pushing it back on causes it open up, and go on easier than it comes off. You definitely don' want it coming off!
GaryHLucas is offline
Marine Head Tank install? cktalons Gear & Maintenance 12 06-17-2011 10:59 AM
Marine Head Tank install? cktalons Gear & Maintenance 0 06-16-2011 11:47 AM
PSC 34 fuel tank mondofromredondo Pacific Seacraft 8 11-17-2009 06:22 PM
Best Way To Install Fuel Tank Martinini Gear & Maintenance 1 06-27-2008 01:56 PM
11.0 Fuel tank S2 Dave S2 1 08-14-2006 11:30 PM
