repairing diesel engine on the dry - Page 3 - SailNet Community
 3Likes
post #21 of 24 Old 10-09-2012
leogallant's Avatar
Originally Posted by Stu Jackson View Post
Never, ever, never, ever connect a hose directly to the engine rw intake. Never.
Here's that "missing link"
Winterizing A Diesel Engine On The Hard - SailboatOwners.com
Not very hard, explains it all.
Ahh, thanks so much. I was going crazy thinking it had been Maine Sail after all, but couldn't find!
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
post #22 of 24 Old 10-27-2012
Re: repairing diesel engine on the dry
I have seen people hook a water hose directly to the engine and blow the seals right out of a brand new water pump, let the engine do what it naturally does, suck the water up.
Paladin is offline
post #23 of 24 Old 10-27-2012
RichH's Avatar
First look at your engine's tech manual for the raw water pump specifications - rpm vs. gallons per minute. Get a large tub (about 10 gallons) and put it into your cockpit' and adjust the water (garden) hose inflow to the tub to be approx. that needed, any spillover from the tube will empty through the cockpit drains. The goal is to keep the tub full when the engine is running.
Most Diesel boat engines in the 30 hp range will need ~3 gallon per minute for running at
~2000 rpm.
Run/extend a hose from the raw water pump to the bottom of the tub, completely fill the hose (no air); start the engine; watch/monitor (need assistant) the level in the tub so that you 'have enough' in the tub at all times.
A cheap plastic mason's tub (Home Depot, etc.) will be in the 10 gallon size range.
RichH is offline
post #24 of 24 Old 10-28-2012
Originally Posted by RichH View Post
.....Most Diesel boat engines in the 30 hp range will need ~3 gallon per minute for running at ~2000 rpm.
I think this a rather light. I never really thought of the GPM of the seawater pump. Having recently winterized, I pumped 5 gallons of antifreeze through the genset pretty quickly, so I looked it up. It has a 13hp Yanmar and pumps 5.5 GPM.
Edit: the 26hp version of the same gen, pumps 13 GPM.
Jeanneau 54DS
Minnewaska is offline
Looking for Used Diesel Engine Loper_27 Boat Review and Purchase Forum 2 06-04-2012 04:56 PM
Diesel engine course in SF bay MarkSF Learning to Sail 7 05-02-2011 05:40 PM
Best book on repairing marine diesel Summercamp Diesel 6 03-22-2010 10:09 PM
Diesel engine help patrickbwells Gear & Maintenance 15 04-01-2007 04:37 PM
Diesel Engine nancisboat Crew Wanted/Available 0 03-13-2001 08:49 AM
