Yanmar YSM8 Oil Leak - SailNet Community
post #1 of 3 Old 09-12-2012 Thread Starter
My YSM8 diesel runs like a million bucks. No smoke at all comes out of the exhaust. Water flows through good and out the exhaust. But.....under load (over 2500 rpms) it leaks a lot of oil. After 3 or 4 hours of motoring I lose over half my oil. I don't see anything leaking when running the motor at the dock under no load. Does anyone have any experience with oil leaks on this antique beast?
sblake1961 is offline
post #2 of 3 Old 09-12-2012
Re: Yanmar YSM8 Oil Leak
I assume the oil ends up in the bilge? There are fluorescent dyes that show up in UV light:
http://www.amazon.com/Tracer-Products-TP34000601-Fluorescent-Detection/dp/B000JFHNTM
that should show where on the engine the oil is leaking from.
Paul T
dabnis is offline
post #3 of 3 Old 08-01-2014
Send a message via Skype™ to billymc38
probably going out the exhaust pipe and into the water worn rings will do that if you are not finding oil in bilge check the crankcase tube going into intake breather see if its full of oil
billymc38 is offline
yanmar ysm8 must it have easystart? culamnelson Gear & Maintenance 5 09-08-2011 09:21 AM
yanmar YSM8 speed suggestions birdlives Diesel 7 12-12-2010 06:41 AM
FYI: To all owners of Yanmar Diesels -YSM8 -found fix to stall problem jrowan Diesel 2 04-14-2010 08:37 AM
Hard Warm Starting Yanmar ysm8 mhfowle Gear & Maintenance 7 12-20-2006 01:45 PM
Yanmar oil leak rskaug Gear & Maintenance 0 01-04-2004 07:08 PM
