Yanmar Transmission Clutch Problem - Page 2 - SailNet Community
post #11 of 29 Old 12-14-2012
jsaronson's Avatar
Re: Yanmar Transmission Clutch Problem
Yanmar say NOT to leave it in gear if you have a fixed prop. It causes the gears to turn without lubrication.
jsaronson is offline
post #12 of 29 Old 12-14-2012 Thread Starter
How would the gears be turning? Engine is not turning, prop is not turning, gears are not turning.
On my boat, sailing in gear, the prop does not turn the engine against compression.
ncapener is offline
post #13 of 29 Old 12-14-2012
jsaronson's Avatar
I'm telling you what the service bulletin says. Leave it in gear at your own peril. I hope that you have your BoatUS membership paid up!
post #14 of 29 Old 12-14-2012 Thread Starter
Do you have a link to that service bulletin? I would like to see if that would apply to my boat/ engine.
ncapener is offline
post #15 of 29 Old 12-14-2012
jsaronson's Avatar
http://www.seawindcats.com/system/fi...%20stopped.pdf
post #16 of 29 Old 12-14-2012 Thread Starter
Thanks a lot for that info!
ncapener is offline
post #17 of 29 Old 12-14-2012
jsaronson's Avatar
Sure!
post #18 of 29 Old 12-20-2012
Originally Posted by ncapener View Post
I don't think that leaving the tranny in gear while sailing is a bad thing.
Yanmar advise against leaving it in gear.
edit: Sorry, didn't see the other posts until I posted this. Tried to delete but fail! Sorry to waste your time.
Goldfinger is offline
post #19 of 29 Old 12-21-2012
Mine will turn if left in forward but not if left in reverse. Left it in reverse for several Pacific crossings, no problems.
Brent Swain is offline
post #20 of 29 Old 12-22-2012
If you leave the transmission in reverse such that the gears cannot turn, how on earth does that wear the transmission??????
I cannot imagine anyone wanting the transmission to spin when you are sailing with motor stopped.
It is just needless wear.
Rockter is offline
transmission problem? sneuman Gear & Maintenance 15 12-04-2012 05:24 PM
do I have a clutch problem? wumhenry Diesel 2 07-01-2011 12:18 PM
Lewmar D1 clutch problem Sanduskysailor Gear & Maintenance 10 06-22-2011 07:35 AM
Transmission problem chacho Gear & Maintenance 5 03-30-2009 12:42 AM
Question on Dipstick for Clutch on Yanmar 2GM PBzeer Gear & Maintenance 6 05-29-2007 08:03 AM
