-   Diesel (http://www.sailnet.com/forums/diesel/)
-   -   zf10m Hurth Marine Transmission Won't Go Into FORWARD GEAR! (http://www.sailnet.com/forums/diesel/92164-zf10m-hurth-marine-transmission-wont-go-into-forward-gear.html)
gary jewett 09-16-2012 11:25 PM
I have a ZF10M Hurth Marine Transmission and I can go into Reverse and Neutral but I can't get it to go into FORWARD GEAR! What should I do I am Lost in this situtation and I need HELP FAST!
Mark1948 09-17-2012 10:00 AM
Re: zf10m Hurth Marine Transmission Won't Go Into FORWARD GEAR!
I had a similar problem with the same transmission. After checking all connections and trying to manually shift using the arm on the transmission, I discovered the bad news and needed a repair job. Sorry for the likely bad news.
PorFin 09-17-2012 10:06 AM
Here's a duplicate of my answer in the other thread:
Gary,
If you are only trying to do this from the helm, you probably should check and see if you can get it into forward at the gearbox (i.e., reach down and pull the lever up and down through all three settings F/N/R). If she goes into gear, then you know that either your cable or control lever is the culprit.
If you can't get her into gear at the box, then somethings amiss internally.
Like Mark mentioned, if you can't get it into gear manually, then a repair is likely needed. The good news is that the ZF10 is a light box, so once it's free of the engine and the shaft it won't be a bear to get off of the boat. Depending on your shaft/prop/rudder set up, you may be able to do this without hauling the boat.
