Universal 5411 Cooling - Page 2 - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Diesel This is a new forum dedicated to diesel engines and their applicable accessories.
Old 10-03-2012
dbruce85's Avatar
Ticon 30
dbruce85 is on a distinguished road
Re: Universal 5411 Cooling
Thanks,
I did look at pricing, you are right.
Has anyone ever found a non marine source for thermostats you could cross reference
  #12
Old 10-06-2012
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Yes, of course. They are Kubota tractor engines. Find a Kubota tractor dealer and order a thermostat. You'll need to know which tractor engine you have:
scroll down Universal 5432 & M40 engine information
NewSite and Kubota Tractor Corporation for dealers near you.
I bought a $42 Universal thermostat from our local Kubota dealer for less than $20!
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
  #13
Old 10-30-2012
Ajay73 is on a distinguished road
I have a 5411 in my 1980 Catalina 27. My exhaust spits out very little water until the engine gets up to 150F. As I motor along the temp gauge will increase slightly over the 150F and then come back down. When the temp increases I get a lot more water flow out the exhaust and then the temp backs down to 150F. My engine runs consistently at the 150F mark. I have had people yell to me that I have no water flow out the exhaust thinking something is wrong like my intake valve is closed.
When I winterized my engine this year I had the marina do the job. They hook up a rubber coupling that covers my intake screen under the boat and then I started the engine. In this case I had water running out the exhaust continuosly and the engine temp only got up to about 125F. I must have had a lot more water bypass the thermostat than normally occurs when operating the engine with the boat in the water.
You may post attachments
You may edit your posts
Universal 5411 or M15 Donaldpeter Diesel 6 06-01-2012 08:42 PM
Universal 5411 cooling system dbruce85 Diesel 0 08-03-2011 07:59 PM
Universal 5411 gbertelsen Gear & Maintenance 2 05-12-2009 10:56 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 07:16 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 06:01 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
