-   Diesel (http://www.sailnet.com/forums/diesel/)
-   -   Yanmar YQM15 - hard starting (http://www.sailnet.com/forums/diesel/92536-yanmar-yqm15-hard-starting.html)
Rusty123 09-28-2012 04:32 PM
Considering purchasing a 1981 sailboat with Yanmar YQM15 engine. There is no hour meter. This model engine does not have glow plugs.
Engine takes about 5 - 10 seconds of cranking before it starts, but seems to run fine after it starts (although I don't have much experience). This is in the Puget Sound, so below decks temperature is fairly cool - upper 40's/lower 50's. Engine manual says that some cranking is normal for cold weather starting.
Should I be concerned that the engine doesn't start instantly? What's considered "cold weather", with regards to engine starting?
marcusc130 09-28-2012 05:24 PM
Do you give it a little throttle when starting? Doesn't seem too bad to me, compared to the 2qm15 I used to have. How does it run under load?
arf145 09-28-2012 08:09 PM
Re: Yanmar YQM15 - hard starting
If I were trying to start my 2GM20F in those temps, it would take 5 seconds or so, and it's a quick starting engine otherwise. Mine starts much better in the cool/cold if I put the throttle all the way forward before cranking and then pull it back to idle right away.
Rusty123 09-29-2012 01:12 AM
That's the way I start mine also. Five seconds, huh? So I guess it's not just me - that makes me feel better.
Engine seems to run fine once it gets going.
arf145 09-29-2012 12:56 PM
It seems like I remember getting that technique out of the Yanmar book somewhere. I've only needed to use it in the later fall. With typical sailing weather temps in the upper Chesapeake (upper 60s on up) our 25-yr-old 2GM20F starts in a second or two with the speed control back at idle.
daddyhop1 09-30-2012 08:39 AM
Living on the east coast we're used to cold starting conditions. I have a 2QM15 and 5 seconds of crank time is about normal. Keep it clean, feed it fresh fuel, and change the oil and it should last a long time.
Brent Swain 11-13-2012 09:54 PM
Light your propane torch and heat the air going in. Adding a bit more weight to the starting handle helps.
junaido 11-18-2012 11:46 PM
Is there any harm to spraying a little "Heet" fluid into the air intake of a Yanmar 3GM30F diesel for cold starts? Its taking longer and longer, 20-30 secs of total cranking spread over two attempts to start it in the cool damp winter of the Pacific NW. I am worried about raw water getting sucked into the engine with all this cranking, not to mention the stress on the starter and batteries. However, one quick spritz of HEET into the air intake and the thing starts on first crank (1-2 secs max). Its a miracle drug as far as I can tell. My only concern is , is it bad for the engine in any way to use this spray ?
chucklesR 11-19-2012 09:01 AM
Originally Posted by junaido (Post 950278)
Is there any harm to spraying a little "Heet" fluid into the air intake of a Yanmar 3GM30F diesel for cold starts? ?
Use as recommended yada yada.. thousands of truckers can't be wrong.
It's better than shoving a propane torch into your air intake (maybe).
It's better than letting the starter get hot enough to warm the engine (certainly).
arf145 11-19-2012 11:53 AM
junaido, have you tried starting with the throttle on max and then immediately pulling back when it starts? This really does work on my 2GM20F. It started up in a couple of seconds yesterday, when the temp was around 50 and the night had been in the 40s.
