Engine paint. - Page 2 - SailNet Community
post #11 of 15 Old 10-01-2012
Once known as Hartley18
Classic30's Avatar
Dock
Re: Engine paint.
Originally Posted by zaliasvejas View Post
All good thoughts to consider...
What about the bolts that get unscrewed/screwed in the course of regular maintenance? Could they be replaced with stainless equivalents? None of them have grade ratings, I assume.. Has anyone come up with a livable solution?
Basically, no. Don't do it. Not on a Volvo. The impact on your wallet of mixed-metal corrosion are not worth thinking about.
Classic30 is offline
post #12 of 15 Old 10-01-2012
Classic30's Avatar
Dock
Re: Engine paint.
Originally Posted by casey1999 View Post
Say you degrease the engine, and remove loose rust, if you use the factory paint (or equal) do you prime first? If so, with what? I was planning on using the Moeller engine paint on my yanmar. Got some of the zinc Chromate primer and the top coat paint which I plan to use. Also have a can of the yanmar engine paint (dark silver).
If one were to only use the yanmar paint, do you just paint over bare metal and rust with it or do you need to prime? If I use the Moeller zinc chromate primer, is this ok to use on bare steel, iron, and the aluminum gear box?
I can only speak of touch-ups on my Volvo MD2040, but I've never primed before spraying with cheap engine enamel and have, to date, had no issues with the paint flaking off after de-greasing and de-rusting first.
post #13 of 15 Old 10-07-2012
Maine Member
BELLATRIX1965's Avatar
Re: Engine paint.
BE CAREFUL!! It's not just about dissimilar metals corrosion - SS bolts do not have the tensile strength of steel bolts - especially Grade 5 or higher steel bolts. Put a SS bolt in the wrong place, and you could have engine parts joining you in the cockpit!!
BELLATRIX1965 is offline
post #14 of 15 Old 10-09-2012 Thread Starter
Seeker
zaliasvejas's Avatar
Re: Engine paint.
You are right, Bellatrix...
There are also torque requirements to consider..
But as far as dissimilar metals go... the fuel pump front cover on my Volvo is aluminum...
Raw water pump is brass... and it all attaches to iron block! Dang, and it all gets painted with the same paint? What gives?
zaliasvejas is offline
post #15 of 15 Old 10-09-2012
Re: Engine paint.
Flat surface corrosion isn't going to be as tough as corrosion imbedded in the threads of a screw that won't back out.
Jeanneau 54DS
Minnewaska is offline
Tags
engine , maintenance , paint , repair , volvo penta
HVLP or Convential paint sprayer, & other paint equipment of choice patrscoe Gear & Maintenance 3 07-11-2011 11:46 AM
Engine: To paint or not to paint aluminum and bronze parts dennisvetter Gear & Maintenance 4 03-19-2011 10:06 AM
Engine Room/Compartment Paint ilnadi Gear & Maintenance 11 12-05-2007 05:40 PM
Engine Paint aruggiero General Discussion (sailing related) 2 07-21-2006 03:37 PM
Engine paint dargiem Gear & Maintenance 2 03-06-2003 08:00 AM
