Universal M25 Overheating Issue - Page 2 - SailNet Community
post #11 of 14 Old 10-28-2012 Thread Starter
Re: Universal M25 Overheating Issue
Bingo! Looks like the mixing elbow did the trick. Took her out yesterday and was able to get up to 2300 RPM with the engine temp steady at about 170. Though I did have to back down to 2100 as the exhaust was putting out some black smoke at that high.
natew82 is offline
post #12 of 14 Old 10-12-2016
did you ever fix your over heating issue?
sen
seancox is offline
post #13 of 14 Old 10-12-2016 Thread Starter
Yes I did. It was a combination of things. The mixing elbow was very clogged, it eventually just got replaced rather than cleaned. After fixing that and changing out the water pump with the grease cup-less model which has a higher flow rate we solved the overheating issue. What we also found was that since it was over heating above 1800RPM the previous owner had installed a much higher pitched prop to run at 5-6knots at 1600RPM, so it was way over pitched and almost lugging the engine and kept the engine from going over 2000RPM which likely contributed to the further clogging of the mixing elbow. We ended up installing a properly sized prop and there after could get the engine up to about 2800 RPM. We cruised all around Mexico and Central America after that in waters upwards of 100 degrees and had zero problems with cooling, we ran the engine sometimes for 3-4 days straight at 2200RPM and not a blip on the temp gauge.
natew82 is offline
post #14 of 14 Old 10-12-2016
Learning the HARD way...
eherlihy's Avatar
A LOT of M25s shipped with a 2" heat exchanger. This H/X is undersized for the M25.
Even more M25s have the hot water heater plumbed in line with the main cooling circuit. Once the water in the hot water tank is hot, this adds another source of heat, and usually a restriction to the main cooling circuit.
eherlihy is offline
Universal Diesel M25X overheating glassdad General Discussion (sailing related) 6 12-15-2011 12:41 PM
overheating M25 BarryL Diesel 5 06-12-2010 08:28 PM
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 11:54 AM
Universal M25 Overheating - Puzzling symptoms endreholen Gear & Maintenance 17 12-10-2008 12:07 PM
Universal M2-12 Overheating phallo153 Gear & Maintenance 10 01-02-2008 10:53 PM
