Trans fluid - SailNet Community
post #1 of 4 Old 10-23-2012 Thread Starter
Trans fluid
I have a 1987 o day. It has a westerbeke 10hp diesel engine. The manual calls for type a or dexron ii trans fluid. I went to pep boys and wm for the fluid and was told they don't carry that type. Since the manual is from 1987 has the fluid name changed ? Have they improved on the fluid and changed the name to dexron 3 or 4 or from type a to b or c. This is all new to me. Any suggestions will be appreciated. Thanks.
jagpfd is offline
post #2 of 4 Old 10-23-2012
Stu Jackson's Avatar
Re: Trans fluid
There are two types of ATF. Dexron is one of them and is up to Dexron IV or V by now, simply improvements to the older "models." You can use one or the other but never mix the two.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 4 Old 10-23-2012
Re: Trans fluid
Correct all dexron fluids are backwards compatible.
stang9150 is offline
post #4 of 4 Old 10-24-2012 Thread Starter
Re: Trans fluid
Thanks for the help.
jagpfd is offline
Navtec Fluid jsaronson Gear & Maintenance 0 02-08-2012 03:00 PM
Transmission fluid Billy654 Gear & Maintenance 2 01-18-2010 06:55 PM
transmission fluid DonStark Islander 2 09-01-2008 03:12 PM
fluid christiner Beneteau 1 02-21-2007 04:50 AM
fluid christinero Gear & Maintenance 3 08-29-2006 12:33 PM
