Vibration in gear - Universal 5424 - SailNet Community
post #1 of 1 Old 11-12-2012 Thread Starter
I get a vibration when in forward gear, that's noticable between 1300 rpm and 2000. So I end up cruising at either 1300 or 2000rpm. It results in cupboard doors etc. vibrating throughout the boat.
The history is that a local boatyard installed a new Hurth transmission, had the prop balanced, and a new propshaft was installed, all just before I bought the boat 2 years ago. It's had the vibration since I bought it.
This is a Universal 5424 with 2:1 Hurth transmission and 3 bladed prop.
I'm assuming the two most likely causes are the prop, and a misaligned driveshaft? How can the driveshaft alignment be improved and can this be done in the slip?
I'm also wondering if the problem could be worn out engine mounts. They are 28 years old now.
MarkSF is offline
Oil filter and V belt for Universal 5424 MarkSF Diesel 1 12-13-2011 12:06 PM
Filling Universal 5424 with oil MarkSF Diesel 3 12-12-2011 02:24 PM
Oil for Universal 5424 MarkSF Diesel 4 06-17-2011 11:42 PM
Tricky reverse gear on Universal 5424 CalebD Diesel 2 05-30-2011 08:36 PM
Gear case for Universal M30 or Model 5424 diesel engine besodelmar Gear & Maintenance 2 09-20-2009 03:01 PM
