Universal M-18 Heat Exchanger - Page 2 - SailNet Community
post #11 of 18 Old 12-07-2012
Re: Universal M-18 Heat Exchanger
Well I think someone got creative after stripping those threads. But the simple fact is, if a zinc anode isn't corroding, the HX is instead. My suggestion is to drill, tap the thread, install a proper zinc.
I found that my chandler stocks all the common zincs so ideally you should take your HX down there to make sure you get one that fits.
MarkSF is offline
post #12 of 18 Old 12-07-2012
Stu Jackson's Avatar
Yup, don't reinstall it without a zinc. HXs are expensive. Zincs aren't.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #13 of 18 Old 11-17-2013
c2csailor
c2cSailor's Avatar
Send a message via Yahoo to c2cSailor Send a message via Skype™ to c2cSailor
I used to have a C27 with a M18 engine and I have a heat exchanger still in the box I never got to install before I sold it. Willing to offer a great price. It's taking up room in my closet. email tjhaibach AT G Mail dot com.
Tim Haibach
Boatless
Texas City, TX
c2cSailor is offline
post #14 of 18 Old 05-24-2014
I removed my heat exchanger drain / plug bolt to check the zinc, and coolant flowed out when I was expecting sea water. Is the M-18 hx drain plug on the engine's right side (looking aft) facing down contain coolant or sea water? if coolant is there another zinc bolt?
martywalters is offline
post #15 of 18 Old 05-24-2014
Tim you still have the M-18 heat exchanger, and still wont to sale it?
let me know thanks
post #16 of 18 Old 05-25-2014
ebs001's Avatar
The zinc anode should definitely be on the raw water side not the coolant side. I have an m25xp and the zinc on its heat exchanger is exactly where you describe the one on yours.
The brass bolt you remove, is it made to hold a zinc? If so there is some reason you are getting coolant in the raw water side. How is the coolant level? Are you getting coolant in the exhaust discharge?
ebs001 is offline
post #17 of 18 Old 05-25-2014
The last time I ran into coolant in the salt water side, the heat ex was toast.
Capt Len is offline
post #18 of 18 Old 05-25-2014
Previous owner installed a non standard HX that works fine but doesn't have zinc bolt. In fact the drain bolt doesn't have an attachment for the zinc to thread in, its just a solid copper bolt ( see attached photos.)
I'm probably going to get a standard HX for my M-18, so I can include zinc in the system and shorten up the hoses.
Oil in Heat Exchanger sailak Gear & Maintenance 38 08-07-2010 08:28 PM
Universal M-18 Heat exchanger jlenox Gear & Maintenance 9 05-02-2009 04:55 PM
Heat Exchanger help DBboat Gear & Maintenance 14 05-20-2008 04:57 PM
Universal M35 Heat Exchanger Replacement SVGratitude Gear & Maintenance 4 12-04-2007 04:49 PM
heat exchanger Jovietal Gear & Maintenance 4 04-03-2007 03:59 PM
