Topping Off Fuel for Winter - SailNet Community
post #1 of 4 Old 11-17-2012 Thread Starter
Someone at the docks indicated that there are two types of diesel at the pumps, recreational (read: what you get at the marina) and non-recreational (read: automotive). He said the only difference is the dyes and that recreational isn't taxed. I am worried about additives that might not mix well with the current fuel in the tanks or that aren't made to hang out in marine environments/engines. Is it OK to find
gas station and pump whatever diesel they have into cans for topping off?
engineer_sailor is offline
post #2 of 4 Old 11-17-2012
Re: Topping Off Fuel for Winter
Some marinas sell ValvTect marine fuel, which has stabilizers and biocides already added. (so we're told). Both are pretty important if you're leaving fuel in the tank over the winter.
Otherwise, I've never heard that road fuel would be bad for a marine motor. It is just taxed differently, which is the primary reason for the color difference. Most buy diesel conditioner and biocides to add anyway, so I don't think it matters to your motor, if you do too.
On the other hand, I've always felt that paying a few more bucks for fuel at the marina is helping keep docks, water, power, parking lots, launch ramps, etc around for us. They don't just exist.
Jeanneau 54DS
Minnewaska is offline
post #3 of 4 Old 11-17-2012
HBar50's Avatar
Click
S/V Bonnie Blue
1987 Newport 30 MKIII
HBar50 is offline
post #4 of 4 Old 11-17-2012
Maine Sail's Avatar
Road fuel and off road fuel come from the same tank farm. Off road gets dyed red. The ValveTect additives are added by the distributor. It is all the same fuel one is taxed one is not and dyed red but they both originate from the same batches & tanks.. ValveTect dealers have stringent test that must be conducted at every fill up. Samples are taken and analyzed in order for them to keep the franchise.
Beyond that all marine engines start life as industrial, truck or tractor engines designed to run, what else, diesel.... Diesel is diesel.. Despite off road not being taxed it is still often more expensive than road diesel...
That said, I drain my tank in the winter...
______
-Maine Sail / CS-36T
Maine Sail is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
topping lift? kirklarsen General Discussion (sailing related) 3 08-29-2009 04:38 PM
topping lift ralphmacey Gear & Maintenance 19 12-24-2008 06:29 AM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
Topping lift PBzeer Seamanship & Navigation 11 02-19-2004 07:39 PM
