Yanmar hoses - SailNet Community
post #1 of 10 Old 12-09-2012 Thread Starter
Yanmar hoses
Noticed recently that that at least two of my cooling water hoses on Yanmar 54hp engine are "sucked" flat.
The top hose from thermostat to manifold is a short 90 degree job, it is the original Yanmar part; just looks very wrong. Same issue with longer hose under the belt cover.
Any comments?
Greguk is offline
post #2 of 10 Old 12-09-2012
Re: Yanmar hoses
Looks like a hose that wasn't intended for suction/vacuum conditions, The first pic doesn't look 'kinked' so much as 'sucked in', as you say...
It all looks pretty new - is this something that's recently cropped up?
Faster is offline
post #3 of 10 Old 12-10-2012
trantor12020's Avatar
Re: Yanmar hoses
Do you have coolant overflow subtank? Maybe something is missing there. Seems like vacuum at work.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #4 of 10 Old 12-10-2012
Maine Sail's Avatar
Re: Yanmar hoses
This is pretty standard on a cool engine especially if it is a little low on coolant. The coolant overflow is only open to the atmosphere if the engine "pops" the inner seal of the radiator cap.. This is a sealed system thus when it is hot the hoses will be full size and when it cools they get sucked in..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 10 Old 12-10-2012
Re: Yanmar hoses
A couple of questions
Are these the origina lhoses from when boat was new? or replacements ?
Typically origina hoses have engine paint over spray on them
If replacement hoses were they from Yanmar and how old
If not Yanmar maybe some one used a piece of straight hose to make the replacement when the actual replacement should have been manufactured with a curve
SawWhet is offline
post #6 of 10 Old 12-10-2012 Thread Starter
Re: Yanmar hoses
thanks all.
looks like a cool engine sucked in. The expansion tank explanation sounds like the issue. (or non issue).
Hoses are original Yanmar so am confident they are correct.
I am okay on coolant level, but the suck in based on temperature change is most likely the cause.
appreciate the experience.
Greguk is offline
post #7 of 10 Old 12-11-2012
Re: Yanmar hoses
Something about the hose clamps(appear to be a size too large) and the missing Yanmar overlay paint on the hoses makes me think they are not OEM parts...but could have been replaced at a later time. Check your expansion tank's hose and 'T' fitting under the pressure cap..could be clogged
aa3jy is offline
post #8 of 10 Old 12-17-2012
Puget Sound Pounder
kellysails's Avatar
Re: Yanmar hoses
Hi Greg,
It seems you have the same engine I do, 4JH5E. I took a pic of one of my coolant hoses after a run then a long period of cooling. Mine does not suck in like yours does. I forgot to get a picture of the other hose, I will do that also.
Sorry for the crappy picture quality.
btw - the first thing I did was to deep six the fan belt cover, it was really annoying to me.
kellysails is offline
post #9 of 10 Old 12-17-2012
Gary M's Avatar
Re: Yanmar hoses
I think SaWhet has it right. On my Yanmar one of the coolant hoses must have been formed with a bend in it.
I did not know where you can buy them, I assume from Yanmar but I had to do some fancy bending to get a straight hose on and not have it hit the Vee belt.
Gary M is offline
post #10 of 10 Old 12-17-2012
Puget Sound Pounder
kellysails's Avatar
Re: Yanmar hoses
I believe the Yanmar part number is 129671-49210. I am assuming you have the 4JH5E. I have the PDF parts manual for that motor. Just PM me where I can send it to electronically.
New Fuel Hoses jlb40514 Pacific Seacraft 4 01-23-2010 08:38 AM
hoses johnharch Pacific Seacraft 3 11-14-2009 09:36 PM
Exhaust Hoses thisisus Gear & Maintenance 3 08-09-2009 06:42 AM
Replacement CNG hoses sailingharry Gear & Maintenance 1 07-20-2009 08:47 AM
Head - Hoses tdw Gear & Maintenance 29 09-19-2008 08:43 AM
