Universal M4-30 Alternator Belt - SailNet Community
post #1 of 6 Old 12-09-2012 Thread Starter
The M4-30 on my boat had a "Carquest" alternator belt. There are two part numbers on it: "7345 XL" and "11A0875"
This is a simple v-belt with no cogs. When I look up 11A0875 online, I only find belts with cogs. There's a spare on board with cogs that does not fit.
I don't know why it didn't use Westerbeke's 302084 belt. I presume one of the the previous owners changed something necessitating a belt change. On the other hand, they might just have grabbed the nearest usable belt after a failure.
Is anyone here know where to find the "7345 XL" or "11A0875" belt?
If not, does anyone here have the measurements (length, top-width) for the 302084 belt so that I can check for fit?
1975 Tartan 30 Competition Rig
eko_eko is offline
post #2 of 6 Old 12-09-2012
Re: Universal M4-30 Alternator Belt
Presumably you can measure yours for reference? or are you a long way from the boat/belt?
This site has lots of listings for comparison.. Universal's ~$40 price seems high.
http://www.vbeltsupply.com/ecommerce...wrapped-belts/
Faster is offline
post #3 of 6 Old 12-10-2012 Thread Starter
A Classic V-Belt Supplier - A Section Belts 1/2' belts
Thanks for the link.
The belt is very badly worn, so these measurements are not precise. It's about 34.5" long, 5/16" wide at the top, and 3/16" deep.
Nothing on that site seems to match those dimensions. If I assume the belt was once wider, the 3L345 (3/8" wide, 34.5" long) seems right. The old belt was loose even at max tension, so I'd probably get the 3L340K (3/8" wide, 34" long, kevlar).
I'd feel better ordering it if someone could share the dimensions of the "proper" Westerbeke 302084 belt.
eko_eko is offline
post #4 of 6 Old 12-10-2012
Stu Jackson's Avatar
If you have it off, take it into an auto store, and get a Gates belt (also carried by Napa).
The XL # is the length.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 6 Old 12-10-2012 Thread Starter
Thanks everyone. Hints from this forum and some extra digging reveals how to parse the part numbers.
7345 XL = 7/32" top-width x 34.5 length
11A0875 = 11mm" top-width (A section?) x 875mm length
That belt had worn down 3mm.
eko_eko is offline
post #6 of 6 Old 12-12-2012
Thanks for the clarification, I knew it was "out there" somewhere.
Suggestion: buy two or three, and throw out all of the old ones. Label them well. Don't ask how I know. (Hee, hee, hee, I always wanted to say that...)
Yanmar 3YM30 Alternator Belt cyphert Gear & Maintenance 13 01-23-2012 08:17 PM
Can't keep alternator belt tight. L124C Diesel 9 06-22-2010 08:13 AM
Need to tighten the alternator belt velero Gear & Maintenance 18 04-02-2010 08:10 AM
ps37 alternator belt size? discoverer37 Pacific Seacraft 2 10-06-2008 11:17 PM
Recommended Alternator Belt + Length jason3317 Gear & Maintenance 3 06-07-2008 12:04 AM
