Hurth Tranny ? - SailNet Community
post #1 of 7 Old 12-12-2012 Thread Starter
aeventyr60's Avatar
Hurth Tranny ?
Any body know where and why a Hurth tranny leaks fluid? I can't see the bottom of the case. Anybody have a diagram or schematic?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #2 of 7 Old 12-12-2012
Maine Sail's Avatar
Re: Hurth Tranny ?
If over filled they can leak out of the vent hole in the fill cap. If you have a leaking rear seal that is another option for a leak and one of the most common, especially when people get penetrating oil on the seal.... This can also be caused by rust working its way into the seal from the metal output shaft and ruining it. The shifter seal is also another possibility..
You need to thoroughly clean the gear then touch with clean white rags to it to find where you are seeing pink on the rag..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 7 Old 12-13-2012 Thread Starter
aeventyr60's Avatar
Re: Hurth Tranny ?
Thanks Mainsail,
Middle of passage in the Mallaca Straits, had to catch the outgoing tide yesterday AM. Now in Langkawi, can take a better look manana, it's one of those upside down, mirror on a stick, take a look see, kinda problems... Like the clean rag idea, gonna have to sacrifice a White T-shirt to the Hurth god.
Have had excellent service from this gear box. Turning 20 years old in January with 4300 hrs, never used a drop before, always regular service, used the same measuring jug, flushed every once in awhile, so maybe a seal or two?
Cheers!
post #4 of 7 Old 12-15-2012
Stu Jackson's Avatar
Re: Hurth Tranny ?
This may help: http://c34.org/manuals/ZF_Hurth_Repair_manual.pdf
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 7 Old 12-15-2012
Brewgyver's Avatar
Re: Hurth Tranny ?
Originally Posted by aeventyr60 View Post
Thanks Mainsail,
(snip)can take a better look manana, it's one of those upside down, mirror on a stick, take a look see, kinda problems...
I find myself using my cell phone more and more to take shots of equipment with minimal clearance, bad angles, etc.
Good luck with your search!
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #6 of 7 Old 12-16-2012
Glad I found Sailnet
Bene505's Avatar
Re: Hurth Tranny ?
I just rebuilt mine last winter due to a leak.
(Can't find the link right now, have to go.)
regards,
Brad
Bene505 is offline
post #7 of 7 Old 12-18-2012
Re: Hurth Tranny ?
aev :
Watch for a wee line of barely-visible rust pits immediately below the lip seal.
They are not easy to see, and the seal cannot live with them.... it leaks, and leaks.
I speak from experience with a Volvo gearbox.
Rockter is offline
Hurth 50 wb-whatever tranny questions degreeoff Gear & Maintenance 4 10-08-2010 10:45 AM
Looking for a tranny for 4-107-4-108 evasion Diesel 1 07-24-2010 08:46 AM
Hurth HBW-5 tranny slipping??? Philschophoto@comcast.net Gear & Maintenance 10 05-22-2006 08:42 AM
Hurth HBW-5 tranny slipping??? Philschophoto@comcast.net Ericson 0 05-17-2006 04:37 PM
Hurth tranny on way to DOA halyardz Gear & Maintenance 1 09-09-2002 07:40 AM
