Cummins 4B 3.3 - Page 2 - SailNet Community
post #11 of 19 Old 12-13-2012 Thread Starter
Courtney the Dancer
jrd22's Avatar
Re: Cummins 4B 3.3
Fast- I thought about that after posting. I might be able to fab up a riser between the mount and the ear on the engine. I would want to talk to someone (more knowledgeable than me) about it but it seems like a good possibility.
Klem- I'll call Cummins NW here in Seattle, I'm not sure why they wouldn't sell you one. I would love it if Cummins did the conversion, but it sounds like Trans A has been doing these for many years with essentially no problems (the lady I've talked to is pretty sharp and been there for a long time). It looks like the Beta is an electronic engine too (not confirmed yet) so that levels the playing field for now.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #12 of 19 Old 06-03-2013
Re: Cummins 4B 3.3
Originally Posted by jrd22 View Post
....but it sounds like Trans A has been doing these for many years with essentially no problems (the lady I've talked to is pretty sharp and been there for a long time)...
I know the thread is ancient..
I spoke to the TA lady also. She knew her diesels.
Somewhere in the thread I saw BT4 comments. Yes, Cummins will sell new to replace existing install. mckaymarinediesel.com had one. They will ask for your serial number of your existing BT4.
My bt4 had only empty rivets where the data plate should be.
BTW.. if you know any good diesel installers (any brand) in the Baltimore-Annapolis corridor please reply or PM. There are many, but it's hard to tell who is good, and who isn't.
bravopapa is offline
post #13 of 19 Old 06-03-2013
Re: Cummins 4B 3.3
Hello JRD22,
The Beta 60 is not an electronically governed engine. The only electronic part of this engine is the stop solenoid.
Stanley
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
The Following User Says Thank You to NCboatrx For This Useful Post:
jrd22 (06-03-2013)
post #14 of 19 Old 05-18-2014
Re: Cummins 4B 3.3
I recently, 170 hours ago, installed a Cummins 4B 3.3M in my sailboat. I was on a trip recently, at a fuel dock and the engine would not restart. After several conversation with both TAD and my mechanic, it was determined the wires going to the starter and the solenoid were too short and under tension and the connector broke off. The wire crimp was still in place and the circular ring lug was under the nut on the connection. Both my home mechanic and the one who worked on it said it was poor workmanship. I called TAD and they helped me diagnosis the problem, but they have no way, no network or mechanics they work with in different area who can perform warranty work. I paid for this myself and was underway, but I will not recommend TAD or this engine again.
sleeper41 is offline
post #15 of 19 Old 05-18-2014
christian.hess's Avatar
Re: Cummins 4B 3.3
so cause wires were too short for the starter you are writing off an engine?
hilarious
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #16 of 19 Old 08-01-2015
Angry Re: Cummins 4B 3.3
I bought a Cummins 4B 3.3 "marine" engine. When I was getting ready to put it my boat I questioned the setup of the raw water exaust system. I told the company I bought it from, that it was for a below water sailboat. They sent directions on how to install it. I questioned these instructions but did follow them. I sailed down to the Caribbean but had problems getting water into the oil. On the way back the engine failed. Sailed to Florida & I had another Cummins Marine dealer look at the engine. The dealer could not find a marine engine like this. Finally the dealer found it was a tractor engine. The original dealer after many calls & many thousands said they would rebuild the engine.
When I got the engine back I had the Florida Cummins design a "bullet proof" raw water system & with his help the engine went back in. Took it out for a sea test; Everything seemed fine. With a year & less than 200 hours the engine is down again & can not get any help from the dealer I bought it from. He even changed his internet ad to :Marinized marine" engine.
I had a Westerbeak in the boat for over 25 years with no problems. I have been working for over 30 years on boats & engines.
Chebob is offline
post #17 of 19 Old 08-03-2015
Re: Cummins 4B 3.3
Chebob ,Is the engine down because the new bullet proof RW system failed or because the original goof didn't do the rebuild right.?
Capt Len is offline
post #18 of 19 Old 08-21-2015
Re: Cummins 4B 3.3
I am in the process of installing a 4B3.3M, which I bought from TAD, in my boat now. However, it may be a few months more before I will be able to start it so I can't comment on vibration. I've nothing but good things to say about Sheri and Marcus at TAD. They are honest and straight shooters. My only complaint about my experience is the lousy and inaccurate engineering drawings they provide online. If you buy the engine, wait until the engine arrives before doing any fabrications in conjunction with the engine logs. You will waste much time if you work from the engineering drawings. Be aware that the 4B3.3M has a number of engine mount options. The online engineering drawings do not specify which mounts that the drawings are dimensioned to.
The 4B3.3M does not utilize a modern common-rail fuel injection system. THIS IS A BIG PLUS IN MY HUMBLE OPINION. It is a simple diesel engine and should be easy to maintain and repair by anyone who is mechanically inclined.
snotter is offline
post #19 of 19 Old 09-09-2015
Schooner Captain
UnionPacific's Avatar
Re: Cummins 4B 3.3
LOL 10K for an engine you can pick up used for under $2000.
You can marinize it yourself.
Lot of companies marinize cummins, you can find a wet header and elbow, and thats all you need.
It will be noisy, but you can run it well past 12,000 hours with no issues.
Please do not spend the $10,000 on a marinized version.
UnionPacific is offline
Cummins 903/Volvo Penta QuickMick Gear & Maintenance 0 03-18-2010 12:02 PM
Cummins 4b3.3 vs perkins 4-154 kmclarke Gear & Maintenance 4 01-26-2007 05:29 PM
Jim Cummins and C-28 Rudder Sensor Installation Joseph Hardin Catalina 1 11-20-2006 08:15 AM
