Yanmar 2gm2f no start after fueling - Page 4 - SailNet Community
 1Likes
post #31 of 37 Old 01-02-2013 Thread Starter
Re: Yanmar 2gm2f no start after fueling
Thanks Morgan73. I actually did get the little primer pump going today after turning the crank till the lever felt like it went a little bit further down with a little resitance, and I saw fuel coming from the bleed screw on the pump/filter canister. then I bled the screw further along under it to the pump (?). then i tried to start the engine and actually got a lttle cough before I stopped because the battery was dying (which is on a solar charger but hadn't set the trickle charger for the 2nd batt, nor had the 25 watt light connected to heat the oil sump). however this was THE FIRST TIME i got any sign of life for some time so am very encouraged!!
Will let you know what happens tomorrow.
alechich is offline
post #32 of 37 Old 01-02-2013
It's been said before no doubt, but worth repeating.. be sure to have your RWC valve shut off until the engine catches for real!
Faster is offline
post #33 of 37 Old 01-02-2013 Thread Starter
Thanks Faster, yeah it did come up before and am religeous about it now but i may have done some cranking before i found out. am hoping it didn't happen (water getting into cylinder). i guess i'll know tomorrow when i try to start with fresher batteries and a warmed oil pan? if it starts it starts right?
alechich is offline
post #34 of 37 Old 01-02-2013
Originally Posted by alechich View Post
.......I stopped because the battery was dying (which is on a solar charger but hadn't set the trickle charger for the 2nd batt, nor had the 25 watt light connected to heat the oil sump). however this was THE FIRST TIME i got any sign of life for some time so am very encouraged!!
You realize that a solar charged does not do much for charging overnight. It would help if you could get a full charge with an automatic charger overnight. A fast cranking speed is also important on that initial startup. It sounds like you are almost done. Did you bleed right at the injection pump? Then the last place is right at the injectors, loosen the fittings one at the time until you see fuel coming out. After starting watch for leaks for a while until you feel confident you have none.
73Morgan is offline
post #35 of 37 Old 01-04-2013 Thread Starter
SUCCESS!!!
Thanks to everyone on this forum that responded to me and helped out. I finally got the little handle on the pump to work just a bit more by moving the crank till I could feel it going a little lower and with some resistance. I had loosed the engine fuel filter and noticed fuel coming out of it, so after it looked like no bubbles (which it did from when I first noticed it)I went to the seond bleeder down to what lloked like the injector pump. THIS WAS NOT IN THE MANUAL. There I did get air out and the tightened down. As per at least two or three commenters, on this and another site (cruisers), I decided to try starting it before going to the injectors, as I stated the other day (when I got just a cough and stopped because I hadn't warmed the oil and trickle charger was not on one battery). It started right off today, with a little extra help of encouragement with the starter. I ran it under load also and checked all fittings. Good as new!!
Thanks again.
alechich is offline
post #36 of 37 Old 01-05-2013
Good idea to have spare filters on the boat. I change mine every year. Since this happened while you were fueling there are 2 possibilities:
1. You just ran out of fuel
2. Your fuel got contaminated. Fuel gets old on sailboats since you normally use so little, moisture/bacteria settles at the bottom of the tank. It gets stirred up when you are fueling or you motor in rougher waters. You might want to siphon some fuel from the lowest point in the tank and see what it looks like, if it is dirty that is your problem.
73Morgan is offline
post #37 of 37 Old 01-05-2013
SUCCESS!!!
Thanks again.
Good news!
Faster is offline
no start Yanmar rchad Diesel 53 10-27-2012 05:08 PM
Yanmar 1 GM will not start fulltilt Diesel 5 10-23-2012 10:31 AM
Yanmar and No Start BarryL Diesel 5 07-22-2012 09:21 AM
yanmar 2qm 20 will not start lordpoltimore Diesel 13 03-08-2010 01:26 PM
Can't start My Yanmar bun243 Gear & Maintenance 8 06-04-2006 01:22 AM
