Perkins 4.108M DIY Rebuild -- A Narrative - Page 10 - SailNet Community
 97Likes
post #91 of 279 Old 02-17-2013 Thread Starter
Seņor Member
PorFin's Avatar
Re: Perkins 4.108M DIY Rebuild -- A Narrative
Sorry, no pics today -- just not up to the whole upload, sort, and cross link kibuki dance tonite.
Got a lot done today, but not much of it was visually exciting.
I reinstalled the oil pump, then spent a bunch of hours at the drill press cleaning up a whole mess of nuts, bolts, spacers, brackets, etc.
I also started masking a bunch of those aluminum parts for an initial primer coat of zinc chromate. Hopefully, I'll be able to get the garage warm enough in the next couple of days to actually spray some paint.
As they say, tomorrow's another day
________
'85 BYB Vagabond 39
PorFin is offline
post #92 of 279 Old 02-18-2013
Senior Moment Member
SloopJonB's Avatar
Does anyone here know why Perkins splits their con rod big ends on the bias like that instead of straight across like every other engine?
SloopJonB is offline
post #93 of 279 Old 02-18-2013 Thread Starter
Seņor Member
PorFin's Avatar
Chapter 12: Killing Time
I figure I owe you a couple of pics of the oil pump reinstalled -- nothing special, just minor progress.
Now, for the killing time part. I'm regretting not doing a better job insulating the garage way back when I first purchased the house and finished the garage. Even with a space heater running, I'm not managing to get the temp up above 60* so I can get some primer sprayed.
So with a little time on my hands, I'm finding creative ways to keep myself busy.
Here's an example. The timing cover is made of stamped steel, and is attached to the block with studs & screws. Since it's made of stamped steel, it's got a fair amount of flex and to spread the pressure from the fasteners over a wider area of the cork gasket Perkins decided to use elongated washers. As you may recall, the timing cover had some serious rust issues around the edges, and many of these elongated washers were also pretty damaged.
Now I could have bought replacements, but what's the fun in that?
I bought some fender washers and fashioned my own that are even longer than the originals!
Here's another example. The connections for our water heater hoses are plumbed into the engine head. They were custom fabricated, although they were pretty rough. Once I got the paint off of them, I noticed that they were stainless. I started cleaning up the welds with a couple of files, all the while contemplating how best to get paint to adhere. Then I thought "why paint stainless?" You may know where this is headed...
After smoothing out the welds a little, I then took the MultiMaster to them with 150, 180, and 240 grit. Pulled out the bench grinder and chucked up a buffing wheel. Voila! Engine bling!
Hopefully tomorrow will get a little warmer...
________
'85 BYB Vagabond 39
PorFin is offline
post #94 of 279 Old 02-18-2013
Closet Powerboater
MedSailor's Avatar
Nice job "wasting" time!
Looking at those elongated washers trying to spread the load on the leaky gasket gets me thinking, "why not drill and tap in some more bolts and washers?"
MedSailor
MedSailor is offline
post #95 of 279 Old 02-19-2013
Por,
I feel your pain. We had double insulation and sheetrock installed in our full basement garage. The workshop seldom gets warmer than 40 degrees Fahrenheit from November to May. Takes a while for glue to dry and even lacquer takes a while.
Enjoy your pictures and narratives.
Paul T
dabnis is offline
post #96 of 279 Old 02-19-2013
Closet Powerboater
MedSailor's Avatar
Originally Posted by dabnis View Post
Por,
Paul T
This problem has a solution.... 28,000BTU
MedSailor
post #97 of 279 Old 02-19-2013
MedSailor
I thought of that but was somewhat concerned about killing myself
I use a small ceramic electric heater on my legs, works fairly well, I can work for about an hour or so, then it is time to come upstairs to warm up.
Paul T
dabnis is offline
post #98 of 279 Old 02-19-2013 Thread Starter
Seņor Member
PorFin's Avatar
MedSailor
That may just work too well -- solvent vapors and a propane heater are usually a risky combo
________
'85 BYB Vagabond 39
PorFin is offline
post #99 of 279 Old 02-20-2013
Closet Powerboater
MedSailor's Avatar
Wus!
MedSailor
post #100 of 279 Old 02-20-2013
Occurs to me, now, Porf, that one of your major expenses will be the acrylic engine box so you can continually admire the result of all this work!
Faster is online now
Tags
diesel , diy , engine , perkins , rebuild
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 03:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-13-2010 11:32 PM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 11:41 AM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 12:43 PM
