Perkins 4.108M DIY Rebuild -- A Narrative - Page 17 - SailNet Community
 97Likes
post #161 of 279 Old 04-05-2013
Courtney the Dancer
jrd22's Avatar
Re: Perkins 4.108M DIY Rebuild -- A Narrative
Some of the engines we rebuilt in my business had the "broken" rods/caps, I always assumed it was so they could only be put together one way but don't really know. Might have been Perkins, or maybe JDeere, but we had a bunch of different brands.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #162 of 279 Old 04-05-2013
I know that Perkins engines were used in a lot of different brands of equipment so they may have been the same!
v40163 is offline
post #163 of 279 Old 04-05-2013
Senior Moment Member
SloopJonB's Avatar
They were even used in the classic black London taxicabs.
SloopJonB is online now
post #164 of 279 Old 04-05-2013
Capnblu's Avatar
Since the bearing surface that moves is on the crankshaft surface, and the bearings are stationary in the rods, wouldnt it make sense to get the undersized bearings, and turn the crank rod journals down the appropriate dimension, after determining your min/max. measurements with plastiguage?
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #165 of 279 Old 04-05-2013
I certainly could do as you have suggested and install 0.010 inch undersize bearings and then "tune" the crankshaft to match the installed bearings by grinding and re-nitriding (Tufftride is the proprietary name) the crankshaft. In fact I used to do almost exactly that on my race motors, although for entirely different reasons...I would have the machine shop finish the crankshaft to 0.0005 inch larger than I really wanted. Then I would hand polish the crankpins and journals with increasingly fine sandpaper and a shoestring to get the exact clearance that I wanted. But that is a lot of work, and I only did it because the engines ran in excess of 9000 RPM and bearing clearances were critical in order to make the motors live.
But crankshaft grinding is forever and in this situation I'd prefer to bring the engine back to new factory specs. Rods are available out there, and it seems that they are not ridiculously expensive.
v40163 is offline
post #166 of 279 Old 04-05-2013
Wish I never found SN!
SimonV's Avatar
Perkins motors are every where in some form of another. In Vietnam they drive pumps in the paddy fields, supplied village water in Fiji, power in the Marquesas and my boat. I think I should start making a a coffee table book of Perkins 4.107/108 motors being used in domestic and exotic locations.
As for New 4.108 they are being made by a number of counties. China build,
Zhejiang Xinchai Co., Ltd. called the 4108BT they also build 4105BT which looks like the old 4.99 which was the original London Taxi motor.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #167 of 279 Old 04-05-2013
Are the Chinese parts interchangeable with their British cousins?
v40163 is offline
post #168 of 279 Old 04-05-2013
SimonV's Avatar
This I don't know but all those engines out there in asia are getting parts from somewhere. Perkins is owned by Caterpillar, and they support factories in India and China.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
SimonV is offline
post #169 of 279 Old 04-06-2013
Have you by chance had any dealings with either the Chinese or Indian arms of Caterpillar? Any idea where I might start poking around?
v40163 is offline
post #170 of 279 Old 04-06-2013
SJB,
I found the answer to your question on rrconnectingrods.com's website: "The angled rod cap is used on small bore engines or for camshaft clearance."
Ray R
SloopJonB likes this.
v40163 is offline
Tags
diesel , diy , engine , perkins , rebuild
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 03:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-13-2010 11:32 PM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 11:41 AM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 12:43 PM
