Perkins 4.108M DIY Rebuild -- A Narrative - Page 21 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Like Tree80Likes
Old 04-15-2013
Capnblu's Avatar
Capnblu is on a distinguished road
Re: Perkins 4.108M DIY Rebuild -- A Narrative
I have a lathe, what are the specs on the alignment tool?
Why, why, why?
I Don't Know! I Don't Know!
Reply With Quote Quick reply to this message Share with Facebook
  #202
Old 04-15-2013
Irrationally Exuberant
arf145 is on a distinguished road
I have got to figure out why I find this so compelling! But I do. Very nice. I'm hoping you'll post some video when you finally start her up on the boat. I'm going to miss your engine, PorFin!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
  #203
Old 04-15-2013
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by PorFin View Post
Med,
I probably could have written that a little clearer.
You shouldn't need an alignment tool, as long as you don't disturb the outer ring of nuts (that's the adapter plate.)
If you only remove the inner nuts (which hold the pump to the adapter plate) you should be golden.
Aaahhhh - British engineering.
Your engine looks great Porf - a job to be proud of.
Are you man enough to total up all the invoices and tell us what the total was?
jimgo likes this.
  #204
Old 04-15-2013
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Blu,
Here's the diagram in the workshop manual:
It's a little over-engineered (e.g., the handle portion really doesn't need to be narrower than the head, the camfer at the back end is unnecessary, etc, etc.)
________
'85 BYB Vagabond 39
  #205
Old 04-15-2013
PorFin's Avatar
Señor Member
What are you trying to do -- jinx me?
I ain't crunching numbers until the baby's running and ready for re-install.
________
'85 BYB Vagabond 39
  #206
Old 04-15-2013
Location: Home in Canada, boat in the Caribbeans at the moment.
Jacques-Andre is on a distinguished road
Porfin,
This is the best step by step rebuilt instructions I have ever read! It is thorough, complete, and with a real "used" engine, not a brand new engine from the factory. Thanks a million for that.
For sure we all want to know how much this will cost, but this is somewhat of little importance as in the process you are learning a lot about your engine, which is priceless! If you have the time, tools and knowledge to do it just go for it.
I also doubt that the "rebuilt" engines that are for sale out there have been cared for as much as what you are doing! This thing will just be like new and good for 10,000 hours for sure!
How about your wife, does she complains that you are spending more time with Miss Perkins than with her lately ;-)
Good job, and thanks for sharing.
Jacques
  #207
Old 04-15-2013
Old enough to know better
miatapaul is on a distinguished road
Originally Posted by Jacques-Andre View Post
Porfin,
Jacques
Not only is it good technically but it is fun to read, I look forward to the posts! I may have to find a boat with a Perkins now, just to rebuild the motor!
  #208
Old 04-15-2013
PorFin's Avatar
Señor Member
More catching up to do...
Chapter 17: Injector Pump Redux
If you are expecting an explanation of how to rebuild the injector pump, you're gonna be disappointed. I let the pros tackle that job.
Now, getting it mounted and timed -- that's definitely something we can do.
FWIW, the pump in question is a CAV DPA hydraulically governed pump.
Mounting the pump can be a real pain in the rear. Access is pretty cramped, and the fastener configuration makes it a little tedious. Here are a few recommendations:
- If you have the Bowman h/x removed, mount the injector pump first during reassembly.
- Use gasket adhesive on the block side if the gasket only, and mount the gasket before you try to install the pump.
- Once you get the quill shaft of the injector pump aligned with the drive hub, move it forward only far enough to get the washers and nut started on the bottom stud. If you move it all the way forward to the block, you won't have enough room between the end of the stud and the injector pump to get the nut on.
- Get the nuts finger tight on the two studs before you try to get the cap screw started in the inner hole.
- For the cap screw, BUY A BALL END HEX WRENCH! (Seriously - you'll be happy you did.) Rotate the pump out (clockwise from the front of the engine) as far as you can, since that should give you a little more maneuvering room around the anti-stall device on the top of the pump.
Once you get the fasteners set up, you can time the pump to the engine.
There are three ways to skin this cat (well, four actually...)
The easiest way is to line up the indexing marks on the pump flange and the engine block -- and pray. Chances are that the engine will run, but it may not run at its best. Basically, you are betting that the external index marks accurately match what's going on internally. If the timing gears haven't been taken off, and the diesel shop has got the pump reassembled correctly, then you're gonna be really close to where you want to be.
But if the stars and planets aren't aligned, then more work is in order.
The next way to do it is using a special tool (which of course your average schmuck like me doesn't have, and oh by the way they don't make any more). What this tool does is let you dial in the external index marks. Since I don't have this tool I didn't waste a lot of brain cells trying to fully understand all the steps and settings to make this device do its stuff.
That leaves us with our last option -- physical measurement of the piston.
There are a couple of ways to do this. The first way is to take a direct measurement before the head is reinstalled on the block. Very simple, very accurate.
The second way is to use the piston drop method. Since I'd already installed the head, that's what I had to do. This is also the method most will use if they are timing the pump with the engine already installed in the boat, so it probably will be useful to other Perky-philes.
I pulled the rocker assembly off to get unfettered access to the valves on #1 cylinder. The workshop manual says to just move one of the rocker arms to one side, but after I looked at the situation for a second I realized that that just wasn't gonna work for me. There was no way I was going to be able to get a valve spring compressor into the game without removing the entire rocker assembly.
After making certain that the engine was at TDC (check the mark and/or the keyway on the crank pulley), I removed the springs from #1 intake valve. I put a piece of locking wire around the top of the valve stem just as a precaution against it dropping all the way into the cylinder if I went too far (the old o-ring groove in the intake stem is perfect for this.)
I set up the dial indicator with the probe on the very top of the valve stem, and rocked the crank back and forth to see exactly where the piston reached its highest point (i.e., TDC.)
Once I verified TDC, I rolled the crank counterclockwise about 30*, and then slowly brought it back up and stopped when the piston top was 0.108" below TDC. I made sure I was measuring on the upstroke (i.e., when turning the crank closkwise) to eliminate any backlash in between the idler gear and the pump drive gear. At that point, I pulled the inspection cover off of the pump to see the static timing marks. I lined up the external timing index marks on the pump flange and the engine block and tightened up the nuts and the cap head screw.
After loosening the three bolts on the drive gear, I used the rotated the hub until the stating timing mark inside the injector pump was aligned with the "A" mark and then retightened the gear bolts. I made new alignment marks on the gear and drive hub. (Alternatively I could have just rotated the pump, but I wanted to keep the external marks accurate just in case I ever need to pull the pump in the future.)
Another bit of "thinking ahead" came to mind: Why don't we add a couple of index marks on the timing case cover that shows both TDC and 18* BTDC? These are just temp marks with a Sharpie -- I've got to think about something a little more permanent...
Then it was just return the piston to TDC, remove the safety wire, and reinstall the valve springs and rocker arm assembly.
Done deal.
________
'85 BYB Vagabond 39
  #209
Old 04-15-2013
SloopJonB's Avatar
Porf, re: external timing marks - go to a speed shop. They have all kinds of timing pointers and so forth. You can even get timing tapes which are marked in degrees and stick to your damper. You need to have the circumference of your damper to know how long a tape to buy.
Edit: Couldn't you have simply put the pin of your dial indicator down the injector hole to measure TDC? It would have saved pulling your valve spring etc.
  #210
Old 04-16-2013
PorFin's Avatar
Señor Member
Funny you should ask...
I gave that a try -- but it didn't work out.
There were a couple of problems. The significant problem is that in order to get the probe through the injector port and then down past the pre-combustion chamber caps, you wind up with the probe hitting the piston at about 45* angle. Now, I love to do a lot of things but higher math ain't one of them. Figuring out the geometry and calculating the adjusted drop measurement just wasn't in the cards.
So, I inserted a small (long shafted) screwdriver into the hole and set up the clock gauge vertically with the probe on the end of the handle. As the piston dropped, so did the screwdriver handle along the y-axis. Unfortunately, the screwdriver was also moving along the x-axis and I couldn't get a true measurement of the actual drop. If I had been willing to sacrifice a screwdriver, I could have simply chopped off the handle at an angle parallel to the block deck.
Overall, pulling the valve springs was less work.
Having said that, somebody with time to kill and a decent shop could probably make a tool.
________
'85 BYB Vagabond 39
Tags
diesel , diy , engine , perkins , rebuild
You may post attachments
You may edit your posts
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 04:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-14-2010 12:32 AM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 12:41 PM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 01:43 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
