Perkins 4.108M DIY Rebuild -- A Narrative - Page 22 - SailNet Community
 92Likes
post #211 of 275 Old 04-16-2013
Re: Perkins 4.108M DIY Rebuild -- A Narrative
I've said it before, but I'm totally amazed at your ability to stop and take the time to document this all with pictures.. and your explanations are succinct and easy to follow. It's great, and this thread should be bookmarked by any Perkins owners out there.
Thanks again, Porf (or should we say Prof )
arf145 likes this.
Faster is offline
post #212 of 275 Old 04-16-2013
Closet Powerboater
MedSailor's Avatar
And what would our Perkins Professor look like anyway?
Like this?
Or maybe more like this?
MedSailor
arf145 likes this.
MedSailor is offline
post #213 of 275 Old 04-18-2013
Location: Home in Canada, boat in the Caribbeans at the moment.
Medsailor. That was not fun. Porfin has been a real sport in sharing with us all that great work.
For your information, mabey Porfin looks like this ! Ok, that would explain why I invited Porfin to help me with my engine ;-)
Jacques-Andre is offline
post #214 of 275 Old 04-18-2013 Thread Starter
Seņor Member
PorFin's Avatar
Med, you got the pics out of order
Before starting (notice the younger man, covered in grease and oil, and smiling in compete ignorance):
After completion (a much older man, no longer amused, but confident in his knowledge of the subject matter):
Faster, arf145, MedSailor and 2 others like this.
________
'85 BYB Vagabond 39
PorFin is offline
post #215 of 275 Old 04-24-2013
PorFin,
I am in Martinique on my sailboat and have looked through the various printed manuals that came with the Perkins 4.108.
There is a "Core and option parts book" that may be the one your are looking for !
It is the Perkins engines North America version 4.108 M
It has a "part number" : NAP000265 PB, Issue 1, October 1981.
It has almost 100 pages.
I seems to be exactly the proper one for my Perkins 4.108 M (1989) with one exception : the heat exchanger is slightly different, it is the one you find on the "low line" 4.108 engines. The shop manual that came with it is the 1983 version, which shows the proper engine on the cover (with the Bowman heat exchanger) but does not show anything about the exchanger in it!!
I guess they may never have made a part manual for the public !?
Anyhow, with that "one and only" diagram of the Bowman I posted earlier it is pretty complete.
If that is the manual you are looking for, I can bring it back to Montreal (in about a week) and scan it for you. I know it is a little late, but it is now that I come visit my boat.
Jacques
post #216 of 275 Old 05-10-2013
Irrationally Exuberant
PorFin, is everything OK? I forget, are you still waiting on some parts? Don't tell me it's all over!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #217 of 275 Old 05-10-2013
Closet Powerboater
MedSailor's Avatar
TEN THOUSAND VIEWS (fans) are awaiting the next installment.
No pressure...
MedSailor
post #218 of 275 Old 05-16-2013 Thread Starter
Seņor Member
PorFin's Avatar
Ahoy. folks.
First, let me extend my sincere apologies to those whom I've left in the lurch -- I should have let everyone know that I was dropping off the net for a little while.
Bottom Line: I will conclude this story complete with (ahem...) cost data, so don't give up hope.
Here's the deal: Now that we're dirt dwellers once again and the weather started to warm a bit, I began to tackle a few "simple homeowner maintenance chores." As a somewhat conscientious older boat owner, I should have known that those words in the quotation marks rarely go together.
I discovered a small leak at our front door. I grabbed a tube of caulk and a putty knife, and figured it'd be a 15 minute fix.
Boy, was I wrong.
As I was digging out the old caulk, I noticed the jamb was soft. Doing some exploratory surgery with the putty knife, I soon realized that painters over the years (while I had the house on the rental market) had applied PVC caps over what they had apparently also noticed as soft wood. All this did was trap water in the wood, and to make a long story short, I've got a new prehung door with sidelights on order.
If the pain ended there, it wouldn't be so bad.
The water that was coming down the wood fibers of the jamb also rotted out the sub sill (another WTF discovery -- the builders used 3/4 OSB on the concrete slab to elevate the door sill to clear the oak flooring; who in their right mind would have used OSB?)
The mission creep continued. The hardwood floor adhesive was beginning to fail, so I tore the floor up in the foyer and am now prepping for porcelain tiles. Getting all the adhesive off the slab was way, WAY too similar to scraping bottom pant for my liking. I still need to hit the slab with a diamond cup to get the remnants off and to roughen up the surface so the thinset will bond well and I won't be faced with tiles popping up too soon.
So, once again, apologies extended and I promise to wrap this tale up once the home project gets put to bed.
davidpm and Jacques-Andre like this.
________
'85 BYB Vagabond 39
PorFin is offline
post #219 of 275 Old 05-16-2013
Glad to hear that you are still alive my friend.
I hope this whole description is about your house, not you boat ;-)
Had about the same experience last summer when I decided to replace the patio door, ended up redoing the whole wall, stripped down to the concrete foundation, changing all the windows and changing the flooring. Looks nice now.
Next project is the Perkins!
Looking forward to the rest of the Perkins story!
post #220 of 275 Old 05-16-2013
bljones's Avatar
As a former door and window pro, I know your pain. Nothing does more damage to the doors and windows of a house than a painter on a budget.
It's 5 o'clock somewhere:
bljones is offline
Tags
diesel , diy , engine , perkins , rebuild
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 04:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-14-2010 12:32 AM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 12:41 PM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 01:43 PM
