Perkins 4.108M DIY Rebuild -- A Narrative - Page 26 - SailNet Community
 97Likes
post #251 of 279 Old 11-15-2013
Learning the HARD way...
eherlihy's Avatar
Re: Perkins 4.108M DIY Rebuild -- A Narrative
Has ANYONE herd from PorFin? His last post was 8-12-2013, and his last login was 9-6-2013... It has been too long.
eherlihy is online now
post #252 of 279 Old 11-16-2013
Capnblu's Avatar
Porfin.....Porfin.... Where are you?
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #253 of 279 Old 11-16-2013
I tried a PM yesterday.. no response. Curious, and sad. Hope he's OK.
Faster is offline
post #254 of 279 Old 11-17-2013
Location: Home in Canada, boat in the Caribbeans at the moment.
Don't you all worry.
He's fine, just has other things in his life than keeping us happy here! Its quite good that he managed to get that much time to devote to this project without someone figuring out he had spare time to do other chores around the house!
Did the door, the living room floor and a few others. Hes fine, just busy!
Porfin, just take the time you need, most of us have nothing better to do that wait for the rest of the story, so no pressure ;-)
But maybe a "I'm still busy at other stuff" kind of message so that we know you are still alive !!
Faster likes this.
Jacques-Andre is offline
The Following 3 Users Say Thank You to Jacques-Andre For This Useful Post:
arf145 (11-18-2013), eherlihy (11-17-2013), SloopJonB (11-17-2013)
post #255 of 279 Old 11-18-2013
Irrationally Exuberant
Well that's a relief! Glad to know he's OK.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #256 of 279 Old 12-10-2013
eherlihy's Avatar
bump...
post #257 of 279 Old 02-09-2014
I just stumbled across this excellent thread and couldn't put it down. I hope Porfin is ok, has anyone heard from him? Fingers crossed...
jamesjle likes this.
Wulf is offline
The Following User Says Thank You to Wulf For This Useful Post:
jamesjle (02-17-2014)
post #258 of 279 Old 03-14-2014
Wow, what a great project. My 4.108 has a slow main bearing leak, so I will be in partial rebuild mode soon I think.
Does anyone know the maker of the great-looking alternator tension fitting that Porfin has used here? I have never see one like this before.
But then again, I don't get out much.
Thanks!
JSROOKS is offline
post #259 of 279 Old 03-14-2014
snake charmer, cat herder
zeehag's Avatar
my 4-108 is ka lunk and has its own thread..... and is touring mexico as we speak, as parts are in casimiro castillo, manzanillo, and joluco.....lol...travels better than i do at this point....will have completely brand new gutz. saved were the cam and crank, and block and head is machines,and the rest is new. thank gods is pesos.
after this i have to go get my jib repaired better, as the repair done was FAIL. and a tank..mebbe i can sail again next year....
formosa 41, cruising tropics
zeehag is offline
post #260 of 279 Old 03-24-2014
Thanks!
JROOKS,
Mcmaster Carr:
9 59915K273 1 Each Ptfe-lined Stainless Steel Ball Joint Rod End, 5/16"-24 Rh Male Shank, 5/16"ball Id, 1-1/4"l Thrd
10 59915K232 1 Each Ptfe-lined Stainless Steel Ball Joint Rod End, 5/16"-24 Lh Male Shank, 5/16"ball Id, 1-1/4"l Thrd
11 8419K12 1 Each Easy-adjust Threaded Connecting Rod, 2" Overall Length, 5/16"-24 Threaded Female Ends
I did the same modification to my 4-108, but took it down to the starboard engine mount flange so as not to have to shorten the tie rods. let me know if you need more info.
cheers
eherlihy likes this.
myt147 is offline
The Following 2 Users Say Thank You to myt147 For This Useful Post:
eherlihy (03-24-2014), Eisregen (03-27-2014)
Tags
diesel , diy , engine , perkins , rebuild
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 04:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-14-2010 12:32 AM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 12:41 PM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 01:43 PM
