Perkins 4.108M DIY Rebuild -- A Narrative - Page 9 - SailNet Community
 97Likes
post #81 of 279 Old 02-11-2013
Maine Member
BELLATRIX1965's Avatar
Wink Re: Perkins 4.108M DIY Rebuild -- A Narrative
Porf: Plus one on the kudos on your internal engine re-paint!
I suspect it is in better shape now than when it was built!
Rest up - there is a lot of nasty stuff going around!
BELLATRIX1965 is offline
post #82 of 279 Old 02-11-2013
Closet Powerboater
MedSailor's Avatar
Porfin, thanks for such an awesome thread! I have a perkins 4.108 myself and I love to turn my own wrenches. In fact, after 12 years of owning old sailboats, I tried to hire a mechanic for the first time ever to do something and he actually didn't want to do the work.
Having said that I like to work on my engines, I've never done anything "inside" the engine. I have to say, now that I've seen you tear yours all the way down, that without a doubt, I am both more, and less intimidated than before...
Keep it coming!
MedSailor
MedSailor is offline
post #83 of 279 Old 02-12-2013
Senior Moment Member
SloopJonB's Avatar
Keep it coming! MedSailor
He's got me wanting to do it again.
SloopJonB is online now
post #84 of 279 Old 02-12-2013
casey1999's Avatar
Been following thread with interest.
Question: My Yanmar 3GMD engine is very rusty. Previous owner had a deck leak directly above the engine. Would be best to pull engine and repaint, but no time to do that in the near future. Would like to clean it up as best I can and paint to protect. Mainly just trying to stop or slow any further corrosion.
The block is cast iron and transmission is aluminum (as well as the engine drain pan). Exhaust and intake look to be cast iron. Plan to degrease engine, remove as much corrosion as I can mechanically, then paint from a spray can.
I have bought some Moeller engine paint, along with the Moeller Zinc Chromate Primer (says for aluminum), and Moeller Zinc Primer (says for steel/cast iron). Can I use the Zinc Chromate Primer on steel/cast iron? Moeller says to use the zinc primer for bare steel, but I doubt I can clean the rust off to bare steel.
casey1999 is offline
post #85 of 279 Old 02-12-2013
SloopJonB's Avatar
Clean all the loose and flaking rust of then hit it with a rust converter before priming.
post #86 of 279 Old 02-12-2013
casey1999's Avatar
Good point. I forgot to mention I have some rust converter. Which primer should I use over the rust converter? I plan to use the Moeller engine paint as a top coat. The only primers they sell are the Zinc Chromate and the pure zinc (advertises as cold zinc paint). Is it ok to use the Zinc Chromate over the rust converter?
post #87 of 279 Old 02-12-2013
SloopJonB's Avatar
Couldn't tell you. I'd talk to a good industrial paint store or call the manufacturer. Personally I'd be surprised if it didn't - Zinc Chromate sticks to aluminium and that's about the fussiest substrate there is as far as bonding goes.
casey1999 likes this.
post #88 of 279 Old 02-16-2013 Thread Starter
Seņor Member
PorFin's Avatar
Chapter 11: Getting Back Underway
After a bit of a break, I'm at it again. The time has come to start putting all the puzzle pieces back together.
Here's today's progress...
First, the tappets and cam went back in. All the red goop on the parts is engine assembly lube (you'll see a lot more of this later). The reason is to prevent galling when the engine is initially started, prior to the oil cycling through all the passages. If I were going to be firing Blue up in the next day or two, motor oil would have been fine. However, since she's gonna be sitting for a while yet, assembly lube's viscuous enough to stay in place much better than motor oil.
Next up was the crankshaft.
Now, being somewhat cautious I decided to do one more check before I torqued the main caps down for good. I used a little Plastigage to double check that the running clearances were not excessive (based on my initial measurements I wasn't worried, but you never know; they might have gotten a little heavy-handed when they were polishing the journals.)
All good to go -- time to move on.
Next was assembling the pistons. My camera battery soiled the sheets, so I don't have any shots of attaching the heads to the cranks. I had to break out the heat gun to warm up components so the wrist pins would slide into the piston head and through the small end bearings -- again, I used a healthy coating of assembly lube on the moving parts.
Installed the rings:
And got ready to install the pistons in the block:
Before installing the pistons, I lubed the inside of the cylinders with ATF. Again, oil probably would have been OK, but ATF supposedly has a few advantages: It won't gunk up the ring grooves, the ATF will burn away a little cleaner, and the ATF will burn away faster which will speed up getting the rings seated.
Anyway, nothing fancy about this...
I didn't take any pictures, but I also took Plastigage measurements of the crank bearing running clearances as well -- once again, all is good.
More tomorrow.
jrd22 and Faster like this.
________
'85 BYB Vagabond 39
PorFin is offline
post #89 of 279 Old 02-16-2013
Closet Powerboater
MedSailor's Avatar
A co-worker of mine rebuilt an engine, and being the exacting fellow he was, he aligned all the splits in the rings so they looked nice. He found out the hard way that you're supposed to stagger the ring splits or oil and compression can sneak past. He was pissed when his newly rebuilt engine was burning oil.
MedSailor
post #90 of 279 Old 02-17-2013
bljones's Avatar
nice piston alignment, and good pics of the plastigauge in action.
It's 5 o'clock somewhere:
bljones is offline
Tags
diesel , diy , engine , perkins , rebuild
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Perkins 4-108M Switch details pbanderson Introduce Yourself 4 04-05-2013 03:03 PM
Perkins 4108 Rebuild Ilenart Diesel 4 02-13-2010 11:32 PM
rebuild perkins 4-108 gavinandrebecca Gear & Maintenance 12 12-14-2007 11:41 AM
Perkins 4-108M 50HP overheating. CharlieCobra Gear & Maintenance 19 10-12-2007 12:43 PM
