glow plugs??? - SailNet Community
 1Likes
  • 1 Post By BarryL
post #1 of 5 Old 12-29-2012 Thread Starter
glow plugs???
Can you check glow plugs,,, Pull them and put power to them???
westerbeke w 21 has 3, do you replace just the ones that are bad, or for 40 bucks each just bite the bullet and change them all,,,, thanks,,, Kevin
nolasailor is offline
post #2 of 5 Old 12-29-2012
Re: glow plugs???
An ohm meter should show if they are open. However, they may not be operating at their peak and for $40 each you are doing about the best you can. Compared with the overall cost of running a boat it doesn't sound too bad.
Paul T
dabnis is offline
post #3 of 5 Old 12-29-2012 Thread Starter
Re: glow plugs???
thats the same thing i was thinking,,, but just checking options....
post #4 of 5 Old 12-30-2012
Tartan 27' owner
CalebD's Avatar
Re: glow plugs???
If one or more of your glow plugs has failed by now it is probably well worth replacing them all if you want your engine to be able start reliably. The other older plugs will likely fail soon anyway so why not replace them all?
The Westerbeke price of $45 per plug does not sound that bad, although still quite inflated.
A little story.
I helped a friend with a Universal engine research the cost of new glow plugs for their 3 cylinder engine. All the marine diesel places (Torreson specifically) wanted > $80 per plug which seemed ridiculously high priced. I was able to cross reference the Universal engine he had to the Kubota engine block that was used and found the same glow plugs available on a tractor/farm equipment website for < $9 per plug.
I believe that Westerbeke engines are based on a Mitsubishi engine block if you care to try to find a better price then $45 per plug.
Everybody has one:
CalebD is offline
post #5 of 5 Old 12-30-2012
BarryL's Avatar
Re: glow plugs???
Hey,
Glow plugs are very simple and usually last a long time. If the plugs pass the resistance check, but are not operating, the problem is usually electrical. As a real quick check, run 12V directly from the battery to the glow plug. Be sure to use a thick wire, like 4 gauge or so. You can use an alligator clip on the battery and the glow plug tip. Be careful because the wire can get HOT. If the glow plug works when connected directly to the battery the problem is the connection.
Barry
T37Chef likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
Diesel Starting - Glow Plugs Siamese Gear & Maintenance 21 10-13-2015 01:23 PM
Glow plugs Classic30 Diesel 12 08-09-2010 06:49 PM
Do all diesels have glow plugs? harbin2 Diesel 18 06-27-2010 11:02 AM
Glow Plugs primerate84 Gear & Maintenance 4 05-23-2010 07:40 AM
glow plugs TheThrill Diesel 22 05-21-2010 02:20 PM
