Ground wire question - SailNet Community
 2Likes
  • 2 Post By arf145
post #1 of 8 Old 01-05-2013 Thread Starter
hillenme's Avatar
While tightening belts today i noticed that the ground wire, which was connected to the mounting bolt for the raw water pump was snipped before it reaches the batt. Any idea why the previous owner would have cut the ground? Could it have been interfering with other equipment somehow? Is a ground to the engine required?
hillenme is offline
post #2 of 8 Old 01-05-2013
Re: Ground wire question
Yes, it is very necessary.
Make sure there is a ground wire from the engine block directly to the battery and make sure it is of the same size as the one from the battery to your starter.
Ahoyhoy is offline
post #3 of 8 Old 01-07-2013 Thread Starter
hillenme's Avatar
I may have incorrectly described the wire I was talking about...
hillenme is offline
post #4 of 8 Old 01-07-2013
Irrationally Exuberant
It looks like that was a small ground wire from some other electrical item using your Yanmar as a ground. The other item might be gone now. Probably not a problem.
hillenme and Ahoyhoy like this.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 8 Old 01-11-2013
I agree with arf145. The engine ground is probably thicker than a pencil, usually close buy the starter.
There is also a possibility that the wire cracked as a result of engine vibrations. Look for a loose wire in the area. Is there something that is not working?
The engine is not a good place to connect accessories. Also, that is why it is a good idea to clean up after making modifications (in this case remove the connector).
73Morgan is offline
post #6 of 8 Old 01-11-2013
OPossumTX's Avatar
Could this be a bonding wire connecting the engine into the protective ground system?
OPossumTX is offline
post #7 of 8 Old 01-11-2013 Thread Starter
hillenme's Avatar
It's def not the engine ground. I know the only equip the PO removed was a water heater, maybe that's the culprit?
hillenme is offline
post #8 of 8 Old 01-12-2013
Seņor Member
PorFin's Avatar
Unlikely -- the water heater would have been a 110v appliance, and the ground wire should have been green. Of course, there's no guarantee that a jumper wasn't used, but still...
Bottom line: If everything's working OK now, then that's just an extra ring terminal that is serving no function.
________
'85 BYB Vagabond 39
PorFin is offline
Yellow ground safety wire aaronwindward Gear & Maintenance 28 08-03-2012 07:41 PM
About to put in wind generator where to connect green ground wire? Mariner777 Electrical Systems 3 06-25-2011 07:04 AM
Ground Wire Fault Problem mgorrell Island Packet 5 06-17-2009 12:53 AM
Ground wire for Raymarine autopilot bene305 Gear & Maintenance 8 04-17-2009 08:17 PM
Remote common ground or individual wire runs? sailboy21 Gear & Maintenance 5 03-03-2008 08:00 PM
