Globe Blue Run Dry impellers - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Diesel This is a new forum dedicated to diesel engines and their applicable accessories.
Old 01-10-2013
imiloa is on a distinguished road
I'd like to hear comments from anyone who has used the Blue Run Dry impellers from Globe Composites. I have an older Sherwood raw water pump on a Universal M-15 that I recently replaced the rubber impeller on that and now I need to pick up a spare. These blue impellers are supposed to be able to run dry for up to 15 minutes. Do they work as well as/better than the rubber impellers? Do they really last longer? Thanks for any comments.
  #2
Old 01-10-2013
BarryL's Avatar
BarryL is on a distinguished road
Re: Globe Blue Run Dry impellers
Hello,
I tried one - it lasted less than a year in my M-21 with Oberdorfer pump, the vanes were cracked where they connected to the center. I usually get 2-3 years from the Oberdorfer models, so no more globe units for me.
Note that I don't really know how long the Oberdorfer models last because I usually just change it after 3 years.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
  #3
Old 01-10-2013
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Originally Posted by imiloa View Post
...These blue impellers are supposed to be able to run dry for up to 15 minutes. Do they work as well as/better than the rubber impellers? Do they really last longer? Thanks for any comments.
Ah... Not that I have observed.
  #4
Old 01-10-2013
Maine Sail's Avatar
I pull my impeller every winter. This is at the end of a 7 month sailing season with about 120 hours of engine use. This impeller was NEVER run dry and never even had so much as even a slight restriction. She pumped a 5 gal bucket empty in under 45 seconds during winterizing with this impeller so flow was very, very good..
I will not comment other than to show the pics..
Before removal:
The various blades:
______
-Maine Sail / CS-36T
  #5
Old 01-10-2013
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
Not a fan.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
  #6
Old 01-11-2013
PhilipStevens's Avatar
PhilipStevens is on a distinguished road
Send a message via Skype™ to PhilipStevens
Thumbs down Re: Globe Blue Run Dry impellers
I had a blue Globe in our Bukh at one time. It was put in at the beginning of one season, removed for the winter lay-up, and replaced at the start of the next season. It then failed to draw in water, and I replaced it with a basic rubber type impeller.
It had never been run dry, and I have never fitted one since.
Not impressed with performance.
I now have a VP2003 (different boat) with a Johnson pump and impeller - and no problems.
regards,
Philip.
  #7
Old 01-11-2013
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
We've had reports of the rubber coming loose from the metal shaft. I don't even consider using them. We have an Oberdorfer 202M-15 on our M25.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
  #8
Old 01-11-2013
Irrationally Exuberant
arf145 is on a distinguished road
I think we might have been misinterpreting the Globe impeller name--they sound more like Globe Run As If Dry Impellers
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
  #9
Old 01-11-2013
Thanks, everyone for the informed replies to my post. Maine Sail, special thanks for the pics - worth at least 1,000 words each. (Your knowledge and experience continues to astound me.)
You may post attachments
You may edit your posts
Storing impellers Minnewaska Gear & Maintenance 32 05-09-2012 01:18 PM
Vendee Globe killarney_sailor General Discussion (sailing related) 21 12-16-2008 07:00 PM
Heads Up w/Impellers on Yanmar DrB Gear & Maintenance 31 10-16-2008 06:03 PM
Places to buy spare impellers? labatt Gear & Maintenance 17 04-25-2007 11:38 PM
Globe Impellers Warren M. Gear & Maintenance 3 08-15-2006 10:21 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
