In reverse while sailing? - Page 2 - SailNet Community
 3Likes
post #11 of 12 Old 01-23-2013
Re: In reverse while sailing?
Originally Posted by Rockter View Post
Well, Yanmar must have a rather strange set-up, but if they say that the gearbox must be left in neutral then indeed you must do so. I can't imagine why, but they know best.
The pressure on the gearbox internal parts causes damage. But do not confuse the gearbox and engine. The engine is not concerned with this issue of sailing in or out of gear. So you can still have a Yanmar with another brand of gearbox and sail in gear.
The idea of a shaft brake is a good one. It reduces wear on the gearbox internals on long passages. An even better idea for some sailors is a feathering prop which reduces drag and helps save the gearbox.
Dan
Transmitterdan
1995 Valiant 42
transmitterdan is offline
post #12 of 12 Old 01-23-2013
PhilipStevens's Avatar
Send a message via Skype™ to PhilipStevens
Volvo Penta MS2 gearbox must be left in neutral when on a shaft driven prop. It's in the owners manual.
If left in astern, it can jam the cones, and if put in ahead, it will wear the cones.
regards,
Philip.
PhilipStevens is offline
Sailing with transmission in reverse-what is that sound? majorm General Discussion (sailing related) 13 03-30-2008 11:08 AM
Reverse ?????? LBSailor General Discussion (sailing related) 22 01-29-2008 04:41 PM
O I 33 reverse 333jim Morgan 2 01-08-2008 09:02 PM
Atomic 4 No reverse jibsheet38 Atomic 4 1 11-22-2006 06:10 PM
outboard reverse cedarpines Learning to Sail 10 09-19-2003 08:20 AM
