Yanmar 3GM30F HP one-hour rating (??) - Page 3 - SailNet Community
 3Likes
post #21 of 25 Old 01-29-2013
Seņor Member
PorFin's Avatar
Re: Yanmar 3GM30F HP one-hour rating (??)
The sweet spot rpm setting for any particular engine installation is going to vary depending on the rest of the factors involved, i.e., displacement, prop size/pitch, etc.
________
'85 BYB Vagabond 39
PorFin is offline
post #22 of 25 Old 01-29-2013
Originally Posted by sck5 View Post
oh and another vote for mack boring's diesel course. They ask what engine you have in your boat and then provide you with THAT SAME EXACT ENGINE to work on for the 3 day course. You will never again get such a good view of the back side of your engine
Also a tour of Mack Boring facility and as I recall they now have an Indian motorcycle dealership as well. Also you can get to get a chance to buy parts directly at their counter at prices more realistic(long story) then from your local marina...
aa3jy is offline
post #23 of 25 Old 01-29-2013
2450 I mentioned was based on the curves data from the manual...
aa3jy is offline
post #24 of 25 Old 01-29-2013
Seņor Member
PorFin's Avatar
Fair enough, but as the saying goes -- YMMV. The data provided in manufacturer's literature are probably based on bench testing on a dynomometer. Actual application variables are going to make those numbers more of a general guideline than steadfast rules.
________
'85 BYB Vagabond 39
PorFin is offline
post #25 of 25 Old 01-29-2013
Exactly and thus I've gone thru 3 prop reconfiguations based on, as you called it, "general guidelines"...
There is another 'Engine Speed' that is not mentioned..but some won't really care..is the 'Max No-Load' speed. However, a good engine(separate from a boat) surveyor will/should note it on his report..
aa3jy is offline
Bleeding a Yanmar 3GM30F jlmarra Gear & Maintenance 11 4 Weeks Ago 07:12 PM
yanmar 3gm30f 1 cylinder bad condition yjchun Diesel 15 09-05-2011 10:59 PM
Yanmar 3GM30F aa3jy Diesel 7 11-23-2009 08:45 AM
Yanmar 3GM30F Bill Mc Gear & Maintenance 30 11-28-2007 07:51 PM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
