Coolant circulation issue - is the water pump working? - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 02-13-2013
Re: Coolant circulation issue - is the water pump working?
Mine was running cold and refusing to warm up. I changed the thermostat and it warms up fine now.Thermostat cost me $9.
Changes in coolant colour can mean its overdue for changing and is no longer anti corrosive. A bit of water soluable machine oil in the coolant can drastically reduce corrosion.
Brent Swain is offline
post #12 of 12 Old 02-14-2013
casey1999's Avatar
If your engine does not regularly overheat, I would think your coolant circulation pumps must be working.
Here is a wild guess at what might have happened. The two coolant types you used where not compatible and did not mix. They also had different densities. So after sitting for a while, they heavy fluid went to the bottom and lighter on top. When you opened the coolant passages, you see different colors in different areas.
If you still have the two fluids, mix them in a clear jar and see if the separate and settle top and bottom.
casey1999 is offline
Overheating/coolant issue alistairc Diesel 9 12-07-2012 10:29 AM
Head pump not working hooligan6a Gear & Maintenance 4 12-25-2009 06:48 PM
bilge pump not working hd1975 Gear & Maintenance 9 07-17-2008 02:56 AM
Odd coolant leak issue Valiente Gear & Maintenance 12 05-08-2007 12:14 PM
Coolant Circulation Diagram Flow MHRitter Gear & Maintenance 0 10-31-2002 09:49 AM
