Injector Removal- Yanmar Engines - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 02-23-2013
Re: Injector Removal- Yanmar Engines
For metal injector fuel lines, I've been told to replace them as well, if the injectors have been serviced a few times. Certainly, not necessary every time. After they've been removed and replaced several times, I understand the flex can be an issue.
That may have been model specific advice from years ago, but you might want to check.
Jeanneau 54DS
Minnewaska is offline
post #12 of 16 Old 03-10-2013
Don't know if you've solved your original issue of injector removal..but a trick that I've learned if the injector is slightly difficult to remove is to use the engine's compression. Be careful and use a heavy rag over the suspected injector as it may fly like a champagne cork but with considerable mass. The O-ring is nothing more then a dust/debris preventer. Also check the pre chambers for wear..should be easy to pull out with a hooked type instrument/tool.
aa3jy is offline
post #13 of 16 Old 03-11-2013 Thread Starter
casey1999's Avatar
Ok, thanks. I will leave the injectors in place for now. Everything is running well, so I will leave it that way. Good to know how to take them out for when the time comes.
casey1999 is online now
post #14 of 16 Old 09-20-2015
can any one tell me if you need a special tool to remove the injectors in a case cx36 3 cyl. motor. it has the hold down plate that I removed cant get the injector out. some one said they screw out but I don't think so please help
firebird is offline
post #15 of 16 Old 09-20-2015
can any one tell me if I need a special tool to remove 3 injectors from a case cx36 3 cyl. motor please help
firebird is offline
post #16 of 16 Old 09-20-2015
celenoglu's Avatar
The engine should be Yanmar. You do not need special tools. Take off the two nuts holding the enjector, pull the enjector. You may need some type of hook to take of the aluminum washer inside the hole between the enjector and the body.
celenoglu is offline
MD17C Injector Pump Removal erps Diesel 10 06-21-2012 08:38 PM
Yanmar YSE12 injector cleaning thedigitalforge Diesel 16 03-11-2011 12:48 PM
yanmar 2qm15 injector pump pfirth Diesel 19 01-21-2011 12:58 AM
Yanmar Injector Rebuilder SteveInMD Gear & Maintenance 5 12-14-2008 12:57 AM
new yanmar engines soapstone Gear & Maintenance 1 02-09-2004 03:57 PM
