Injector Removal- Yanmar Engines - SailNet Community
 3Likes
post #1 of 16 Old 02-21-2013 Thread Starter
casey1999's Avatar
I have a Yanmar 3gmd and have question on fuel injector removal. Looks like all Yanmars have similar injector arrangement.
How do you remove and reinstall an injector?
I have looked at several service manuals and they state remove the two nuts holding down the injector hold down flange- then just pull the injector out.
But there looks to be (from parts drawing) a lot of gasket, and o-ring, and insulators that are between injector and the head. Do you just leave these in if you plan to either replace or service the injector. Or do all or some of these parts need to be replaced when you reinstall the injector?
casey1999 is offline
post #2 of 16 Old 02-21-2013
Re: Injector Removal- Yanmar Engines
Not real up on Yanmars, Casey, but in my experience any and all seals/washers/ etc involved in injector installs are one time use only except perhaps in an emergency.
Faster is offline
post #3 of 16 Old 02-21-2013 Thread Starter
casey1999's Avatar
Yes that is what I normally do. All these parts (o rings, insulators, washers) are deep in the head after pulling the injector. They look to be difficult to remove and to be sure you have all the items out. They can (or parts of them) fall into the injector hole then foul the cylinder (once in the cylinder, nearly impossible to remove). Normally the manuals I have specify to replace a gasket or o-ring, but with the injector removal, the manuals mention nothing.
post #4 of 16 Old 02-21-2013
A crochet-hook type tool can be helpful to try to remove those kinds of things and NOT drop them down.. but will they actually fit down and clear into the cylinder? Our Bosch seal rings wouldn't...
Faster is offline
post #5 of 16 Old 02-22-2013 Thread Starter
casey1999's Avatar
Hook is a good idea. One of the parts is called an "insulator". Imagine it keeps the heet of combustion away from the fuel injector. Normally engine type "insulators" are made out of an asbestos or similar material. This material is normally somewhat brittle and breaks up into parts when you attempt to dis-assemble.
post #6 of 16 Old 02-22-2013
overbored's Avatar
the parts below the injector are the insulator which is a fiber disc and needs to be replaced the pre combustion chamber does not. I found that I could buy a new injector for less then having the shop rebuild them. $100 each and $125 to rebuild, but then I only have one.
Yanmar 1GM10 factory manual 7232154-Download_Service_Manual_Yanmar_1gm10_2gm20_3gm30_3hm35.pdf (.jpg
bljones likes this.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #7 of 16 Old 02-22-2013 Thread Starter
casey1999's Avatar
So after you pull the injector out can the insulator be removed easily? Did you also replace the O-ring?
post #8 of 16 Old 02-22-2013
overbored's Avatar
the insulation washer fits down in to a recess on the top of the pre-combustion chamber and can be dug out with an awl or the like. it is a aluminizsed fiber washer, like head gasket material. the o ring is up around the top of the body of the injector and helps keep moisture from getting down the side of the injector so it does not rust and make removal at a latter date difficult. On mine the pre combustion chamber was changed and required the head be removed and a 10 ton press to get it out. the PO's so called mechanic did not put in an o ring and the parts were rusted in. he told me it was not needed so he left it out. he also told me that the injector was still good and when i remove it the nozzle hole was about twice the size of the new one. he doesn't work on this engine anymore.
bljones and casey1999 like this.
post #9 of 16 Old 02-22-2013 Thread Starter
casey1999's Avatar
Thanks for the advice. How did the engine run with the large injector nozzel hole?
post #10 of 16 Old 02-22-2013
overbored's Avatar
it ran but very rich and a lot of black smoke with any rpm above idle. the engine was rebuilt about 5 years before I bought it. but they put on all the old stuff. the PO was tired of fixing the engine problems. which helped lead to him sell the boat. the compression checked out good. I replaced the entire fuel system. injectors, fuel pump, injection pump, lines, hoses, added a Racor and cleaned the tank out. set up the timing and adjusted the valves correctly. spent about $800 and $180 for new water pump, now it should be good for quite a while.
MD17C Injector Pump Removal erps Diesel 10 06-21-2012 08:38 PM
Yanmar YSE12 injector cleaning thedigitalforge Diesel 16 03-11-2011 12:48 PM
yanmar 2qm15 injector pump pfirth Diesel 19 01-21-2011 12:58 AM
Yanmar Injector Rebuilder SteveInMD Gear & Maintenance 5 12-14-2008 12:57 AM
new yanmar engines soapstone Gear & Maintenance 1 02-09-2004 03:57 PM
