Yanmar 2GM20F Oil pan leaks - SailNet Community
 2Likes
post #1 of 22 Old 03-04-2013 Thread Starter
trantor12020's Avatar
I notice oil drips from under my 2GM20F even when engine hasn't run for a week or two. On closer inspection (with a small mirror) I see oil forming at the oil pan gasket right under the engine. There was no oil drips/oil stain from higher up the engine body. Question is can I remove the oil pan and change the gasket as is without hoisting the engine out? I think I can access all the 16 or 17 bolts (10mm AF ?) underneath.
Meantime, I've retighten all the oil pan bolts (some weren't very tight) and will check it again coming weekend to see if it is still leaking.
chickl likes this.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #2 of 22 Old 03-04-2013
Re: Yanmar 2GM20F Oil pan leaks
You know, I have a similiar problem with my Yanmar but I believe the Gasket between the Transmission and the Engine has a slight leak. My oil is very clean. Looks like pulling the engine is the only way to get to my problem.
chickl is offline
post #3 of 22 Old 03-05-2013 Thread Starter
Mine is black so pretty sure from crankcase. Seems like unbolting the oil pan is do-able if the bolt heads are not rounded and I should get a suitably long 10mmAF socket spanner.
Planning: warm up engine, extract as much oil, lay out plastic sheet under engine, stack oil absorbent on top of plastic then undo oil pan bolts. Let remaining oil drip. Clean up pan and box up with new gasket. Pat myself on the back and have a cold beer. Hope its as easy as it sounds. I'm not inviting Murphy to this party. Hope he don't gate crash.
Ken
post #4 of 22 Old 05-14-2013
rhpaw's Avatar
How did it go?
I have the same issue.
S/V Serenity- S2 9.1
Rode Hard, Put Away Wet
rhpaw is offline
post #5 of 22 Old 05-14-2013
L124C's Avatar
Don't taunt Murphy!
Originally Posted by rhpaw View Post
How did it go?
Yeah...I'd like to know myself.
That sounds like a party thrown by Murphy's family! Especially when you taunt him with the vision of you relaxing with a cold beer!
Only his vision has all your knuckles bleeding, your bilge full of oil, having pulled the motor to remove broken bolts and get the pan back on, and you curled up in the V berth, nursing from a bottle of Jack Daniels, muttering, "Ya know....I could have lived with that damn leak"!
Oh...And six months later, you discover you have the same leak with the new gasket!
Hope I'm wrong! How did it go?
L124C is offline
post #6 of 22 Old 05-15-2013 Thread Starter
Well upon further investigation, I found the leak to be from the engine front cover. Leak somewhere near or between the 2 lower bolts. Oil drips down from there and along the oil pan. For now, the plan is to leave it and see how far the level will drop to. If its settles above the minimum level then fine. No need repair. So far level is 2/3. Fingers cross.
PS: I bought the pan gasket but looks like not needed.
Ken
post #7 of 22 Old 05-16-2013
L124C's Avatar
If the area under the motor is dry (except for oil of course!) disposable baby diapers work great for absorption. My 30 year old 2GM20 leaks a little, but not enough to effect oil levels. Certainly not enough to deal with Murphy! One diaper easily lasts me a year. Now, if you are going through a diaper a week......
L124C is offline
post #8 of 22 Old 05-18-2013
old guy :)
rikhall's Avatar
Ken - If the leak is between the front area and the main motor it is a known Yanmar 2GM20F problem and "should" be covered by warrantee - mine wasn't - they stonewalled me and I ended up paying for the work myself - and I paid top dollar because of the marina where I was stuck.
From the sound of it you have a break in your timing gasket.
You need:
one timing gasket (part 1215701512) was $17.79 in 2006
one gasket (part 1215701861) was $1.70 in 2006
two "O" rings (part 24311000100) were $1.38 each in 2006
That's all.
More info:
"Yanmar have produced a new steel reinforced gasket to combat the problem p/n 121575- 01512. Other parts required are side cover (inspection plate) gasket p/n 121575-01861 oil way o-rings x2 p/n 24311-000100"
and more:
"This is the Yanmar technical bulletin that deals with a timing cover issue. The bulletin # MSB-02-003 must accompany any warranty claim that is submitted. "
It is a simple job to replace the gasket and two "O" rings. No need to drain the oil nor the water.
The new "metal" type gasket that replaces the old "paper" gasket.
PM me if I can give you more details. I have pictures.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #9 of 22 Old 05-19-2013 Thread Starter
Rikhall, my engine no longer has warranty. Was no leak for about 10 years. Just pass 10 years. Appreciate pictures. Will PM you my email. From how I see it, it wasn't an easy fix. Not sure if its the same timing cover you refers to. Hope so.
Ken
Ken
post #10 of 22 Old 05-19-2013
old guy :)
rikhall's Avatar
Ken
Pictures at https://picasaweb.google.com/RikHall...NH3m5iI4PvD8gE
I hope it is the same as what I had. Easy fix.
Rik
Irwin Citation 34
Mystery
rikhall is offline
Yanmar 2gm20f Ilijanik P30 8 02-28-2013 09:29 AM
yanmar 2GM20F moskalm Diesel 4 01-30-2013 06:30 PM
Yanmar 2GM20F 73Morgan Diesel 10 12-31-2012 06:57 PM
Yanmar 2gm20f RPM RobGallagher Diesel 2 06-30-2012 03:24 PM
Yanmar 2GM20F Petar Gear & Maintenance 13 10-02-2009 06:49 PM
