Replace Diesel Fuel Line - SailNet Community
 1Likes
  • 1 Post By Minnewaska
post #1 of 4 Old 03-07-2013 Thread Starter
I would like to replace my tank to engine diesel fuel line. I would also like to add a fuel shutoff valve. Does the tank have to be empty to accomplish this?
Bake81 is offline
post #2 of 4 Old 03-07-2013
Courtney the Dancer
jrd22's Avatar
Re: Replace Diesel Fuel Line
Not usually if it's a standard type suction line out of the top of the tank. Obviously, if the line comes off the lower part of the tank you could have a problem :-))
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 4 Old 03-08-2013
gts1544
Bake81, It sounds like you have a good start by adding a shut off valve at the tank. I would strongly suggest that you add a good RACOR type diesel fuel filter between the shut off valve and the engine, if you don't have one. Diesel engines are very susceptible to any dirt particles in their fuel. Make sure that you know what flow rate that your engine requires at full throttle and choose your filter accordingly. I would highly recommend a filter with a water settling bowl on the bottom with a drain valve to drain water or sediment. Said filter should also allow you to change the filter element without having to bleed the fuel line for admitted air. Best of luck! gts1544
gts1544 is offline
post #4 of 4 Old 03-08-2013
Good excuse to empty and clean the tank while you're at it? Not sure why you are replacing fuel lines, but could the reason exist in the tank too?
kellysails likes this.
Jeanneau 54DS
Minnewaska is offline
Diesel fuel line installation Waltthesalt Diesel 6 02-16-2013 11:53 PM
Scotty, (Replace Old DC Breaker Panel) When Will I Have My Warp Power On Line ? HighFly_27 Electrical Systems 4 11-09-2012 07:37 PM
Replace Diesel Fuel Regularly maccauley123 Diesel 19 05-22-2012 12:56 PM
Fuel tank clean/replace Cal 29 Atomic 4 banty2 Cal 5 08-18-2010 10:18 PM
Should we replace our fuel in our new-to-us boat? josrulz Gear & Maintenance 21 02-04-2009 01:28 PM
