oil pressure sender Yanmar 2GM - SailNet Community
post #1 of 3 Old 03-13-2013 Thread Starter
boz86's Avatar
I went to troubleshoot my oil pressure sender last night (no warning tone/light before start), and had trouble getting the cover off the front where the wire enters the sender.
I didn't want to yank too hard and risk breaking something that would leave me rewiring around the engine wiring harness.
Anyone know which direction that cover comes off? Pull straight out, twist, something else?
Thanks
"The Stone Age did not come to an end because we ran out of stone." Sheikh Yamani
boz86 is offline
post #2 of 3 Old 03-17-2013 Thread Starter
boz86's Avatar
Re: oil pressure sender Yanmar 2GM
Found the answer so I figured I'd post in case anyone needs to know and searches.
There's a boot that should slid back uncovering a phillips head screw on the sender. My wire's boot had pretty much welded itself to the wire and didn't pull off without breaking the wire ring.
Turns out that part had failed, which is why my alarm wasn't working. So no loss breaking the wire ring/connector.
Thanks to Scott at AR Marine of Annapolis for giving me the answer.
boz86 is offline
post #3 of 3 Old 03-18-2013
Irrationally Exuberant
Thanks for following up and adding to the knowledgebase, boz!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
Yanmar YM oil pressure alarm failure ctlow Diesel 10 04-10-2017 10:02 PM
Oil pressure sender Hudsonian General Discussion (sailing related) 1 12-15-2010 01:11 PM
Yanmar Oil Pressure Searunner37 Diesel 5 07-29-2009 06:45 PM
Yanmar Oil Pressure Light/Alarm Out? Please help! gwp Gear & Maintenance 1 05-19-2008 11:32 PM
Yanmar oil pressure brak Gear & Maintenance 4 05-04-2008 09:40 PM
