broken motor mounts - SailNet Community
 1Likes
  • 1 Post By eherlihy
post #1 of 5 Old 03-18-2013 Thread Starter
bristol299bob's Avatar
broken motor mounts
I'm in the process of swapping my trans for a new one (well, it's new to me anyway). While removing the old trans I discovered that all 4 mounts were broken!
the center bolt sheared on each one. All but one appear to have sheared a while ago (only one had that shiny, just broke, look to it)
I did notice that it was shaking more and more but I didnt put 2 and 2 together.
I checked for cracks and signs of banging around ... the stringers look fine. Is there anything else I should check ... any problems or damage that a loose engine could cause?
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #2 of 5 Old 03-18-2013
T37Chef's Avatar
Re: broken motor mounts
I would check just about everything pertaining to the transmission, shaft for true, cutless bearing, strut (if applicable), and of course alignment will have to be adjusted after you do all the prior checks.
Perhaps you could post a picture
Shawn
T37Chef is online now
post #3 of 5 Old 03-19-2013 Thread Starter
Thanks Chef, I'll get some pics soon.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
post #4 of 5 Old 03-25-2013 Thread Starter
Here are some pictures, I've replaced the mounts of course. And the vibration is lessened now of course. You know what they say about boiling a frog ... I think the vibration was getting worse slowly over time and I just didnt notice that I was being boiled to death ;-)
I checked out as much as I could (with boat in the water) from the coupling aft. I could not find any damage but I'll be hauling her in a month or so for the final word.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
post #5 of 5 Old 03-26-2013
Learning the HARD way...
eherlihy's Avatar
Thank your favorite diety that you did not wrap a line around your prop. while motoring. This could have had a whole different outcome!
I would also closely examine the exhaust system (elbow, etc.)
bristol299bob likes this.
eherlihy is offline
broken westerbeke engine mounts in 331 finney Gear & Maintenance 1 01-29-2013 01:45 PM
C&C 33 motor mounts barryschnur C & C 1 08-31-2011 06:48 PM
anchoring issues - broken motor mounts Barry33 General Discussion (sailing related) 9 07-27-2009 09:09 AM
Broken engine mounts lgsailor19 Gear & Maintenance 3 06-03-2004 12:46 PM
Stanchion motor mounts bsfree Gear & Maintenance 0 06-07-2002 09:27 AM
