Sender units for Farymann - SailNet Community
post #1 of 5 Old 03-20-2013 Thread Starter
Hi. We purchased a boat with a Farymann A30 engine. The engine itself works fine but the engine instruments do not work. We knew this before buying. I want to update the instrument panel and would like to know if anyone has changed the oil pressure and water temp sensor. The reason I'm asking is because the boat is not been shipped to us yet. I did get a manual for the engine but its in German and does not really give thread sizes. Trying to get things ready for when she does arrive. Any help would be appreciated.
Rod
RodH is offline
post #2 of 5 Old 03-21-2013
Re: Sender units for Farymann
This engine only has a temp switch for a temperature alarm. Farymann never supplied a gauge.
There is no provision for an oil gauge as this engine is splash lubricated.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #3 of 5 Old 03-21-2013 Thread Starter
Thanks. I really need to learn to read German. That makes life easier. This engine was put in a C&C 29 to replace the Atomic 4. I guess that's why the only gauge that works is the fuel gauge. A water temp switch and light it is. Thanks again for for your help.
Rod
RodH is offline
post #4 of 5 Old 06-23-2013
I am in the process of purchasing a Cascade 29 with a Farymann A30 engine, with low hours, and owned by a diesel mechanic, so it is in great shape for it's age. In the process I found both the owner's instruction manual and repair manual in english. I can either email you the PDF's or links if need be.
My tachometer doesn't work and will need to replace that ASAP, the previous owner kept a log of the engine hours after the tach stopped working.
stpsailor is offline
post #5 of 5 Old 06-23-2013 Thread Starter
Thanks. I have an owner manual but a repair manual would be great. Either a PDF or link works for me. Whatever is easier for you. Thanks again Rod.
RodH is offline
oil pressure sender Yanmar 2GM boz86 Diesel 2 03-18-2013 02:34 PM
Oil pressure sender Hudsonian General Discussion (sailing related) 1 12-15-2010 01:11 PM
Add fuel sender Mystiko Diesel 2 12-06-2009 11:56 PM
mast head sender mike dryver Gear & Maintenance 0 05-14-2006 06:37 PM
First Challenge and Success-- Temp Sender Jim H Atomic 4 0 04-10-2006 09:04 PM
